I have another question about orm generation especially concerning the “nullable” property which appears in SQL table but not using ORM Persistable java class!
How can I configure attributes classes to turn nullable value from false into true. I don’t understand why some programming type like Date are set to true and some others like int are set to false?
Thanks for your post. “nullable” is specified in columns of entities (then sync to from ERD to class diagram). If the column is nullable, you can set nothing to the attribute in runtime. Otherwise, you must specify the values to the attribute.
Hope this answers your question. If there is any further inquiry, please feel free to ask.
it’s already what we’ve done right now. However, it’s not an efficient manner of generating ORM.
Actually, we have used so many times the ORM Wizard (ERD generation and Code generation) so
we can’t modify the ERD before generating code.
Why don’t you propose to configure ORM persistable attributes in class diagrams?
Could you add this information in class diagram or to provide an option in wizard box,
more precisely in ERD one to configure “nullable” property of each field.
Thanks for replying. Since nullable is database related, it should not be modeled in class model. You can synchronize your class diagram to ERD, then edit the column to be nullable/not nullable on ERD. After that, you can run Tools > ORM > Generate Database to generate the database from ERD.
