Code generation coverts all package names into small case. I have detailed my problem below. Is there a way to avoid this lower case conversion of package names ?
In my project, we are using third party object model which has package names with upper and lower cases. In our own object model (created in Visual Paradigm), we duplicate the some package structure and classes found in third party model, when our classes need a relationship with third party model classes.
The duplicated package structure should be exactly same as found in the model we purchased. So such packages need to be in mixed case as well. Unfortunately the generated code converts everything into lower case, and we are not able to use the generated code.
How to avoid this lower case conversion ?
Hi Rameshg,
Thanks for drawing our attention on this issue. I’ve forwarded the issue to our engineers to investigate. Once there is any feedback, I’ll notify you immediately.
This problem is severely affecting our schedule, bcos we have to manually change the package names and then compile the source code each time we make an update to object model.
Hope a resolution will be provided asap.
Hi Rameshg,
I would like to let you know that our engineers have studied this issue and we plan to support following upper/lower case of packages in ORM code generation in VP Suite 3.4 (DB-VA 4.4), which will be released around October.
If there are any news about this issue, I’ll come back to you at once. If you have any inquiries, please do not hesitate to ask.
Hi Rameshg,
I notice that you have submitted a ticket regarding to this issue and we have replied with the latest news of the issue in the ticket system. Please have a check in your ticket, you are welcome to contact us if there are any question.
