We have a floating license server in use. In order to keep the licenses available we want to prevent the functionality to check out and take away licenses locally. Is there any switch to achive this on the license server?
Thanx
Olaf Port
Thanx
Olaf Port
Hi Olaf,
Licenses in-use will be released after exiting the application. It won’t be taken away unless a team member export that from server. Even if he has exported the license, he can import it back to the server later on.
If there is anything else that I can do to help please do not hesitate to ask.
Hello Jick,
the checkout/checkin process of licenses is completely understood. What I try to do is to disable the export functionality on the floating license server completely, so that no one can export any licenses to begin with.
Is that possible?
CU Olaf
Hi Olaf,
I regret that we do not support this feature. I’ve forwarded your request to our team for further feasibility studies. Thank you for your post.
