It appears that I’ve installed the SD for Eclipse successfully (I got blue screen of death on the first try though). But it kept complaining that I don’t have the complaint JRE to run it (see attachment). But I switch from JDK to JRE (see attachment) Any idea?
Your runtime environment is old. SDE requires 1.4.2 and above. From your second screenshot, it shows that you have 1.4.2_04 but you have not ticked it. You should use the newer Runtime environment.
I have the same problem as well with Eclipse 3.0 and SD for Eclipse (Enterprise Edition) V2.
How did you resolve it?
-Anuja
[quote=Randy]Hi,
Thank you for your message. Could you mind send me your email address so that I can send you the JRE to have a try? You can send me your email address through private message or send to rain@visual-paradigm.com. Thanks in advance!
Was the problem ever solved? I have the same problem in Eclipse 3.2. It complains that it needs JRE 4.1.2 or higher when I start the SDE-EC. I have loaded both JRE 4.1.2 and JRE 5.0.
I have changed the JAVA/Installed JRE to JRE5.0 in Eclipse Preference. I have changed the system environment variable to JAVA_HOME and PATH to point to the folders accordingly. Still the same problem.
