Problem installing SDE Community Edition
Hi, I recently downloaded SDE Community Edition, but I have a problem installing it. After running the bash script, the installation window appears but I’m not able to see any of the controls on it, so its impossible to go forward with the installation. Does anybody know a workaround for this??? By the way, I’m trying to install SDE on Ubuntu 8.04 Eclipse Platform
Version: 3.4.1
Thanks in advance
Alejandro
Hi Alejandro,
Thanks for your post. Please try to disable the Desktop Effects and see if the problem is solved.
If this does not help, please try the solutions in the following resources page and see if your problem can be solved:
http://resources.visual-paradigm.com/index.php/tips-support/53-support/61-blank-screen.html
If there is any inquiry, please do not hesitate to contact me.
Thanks a lot…I disable the effects and installed it without problems…
Hi Alejandro,
You are welcome.
