I have an issue with copying a pool with three lanes. I want to have a copy with no model sharing.
Either by trying “duplicate” or “Paste Model” the first and third lane are somehow switched around. Original has Lane1, Lane2 and Lane3 from left to right; the copy will have Lane3, Lane2, Lane1.
I tried to just rename the lanes and go from there; doesn’t really work out either, as I cannot properly adjust the border ranges of the lanes. Lane1 in my model has to be much bigger than lane3. Result for me is, that my activities are part of the wrong lane…
Hope somebody can help. I am still trying out with an evaluation copy and I will be able to work around, but for the future use of the program, the copy and paste stuff has to work properly, I believe.
As the download is pretty big (120MB) I want to get sure that it is what I am searching for…
I was searching for fix, to be able to copy a pool with three lanes from one BP diagram to another and I don’t want the same model for that. Meaning I want to change the original without having the copy being changed and vice versa.
Your download description says that a JPG export bug was fixed in there?!
Also I am not running Visual Architect 3.0, but Business Process Visual Architect 2.0 (Analyst Edition). The .exe seems to be related to VA 3.0
Replace $bpva-install-dir/lib/vpplatform.jar with the downloaded jar file
Restart the application
Note:
