I’m currently evaluating the SDE for Eclipse package and I have quite some problems with the code generation.
In fact, I’ve designed a class called test. I’ve selected “update to code” so that the class has been generated. Now, I’ve added 2 stereo types : Entity Bean and ORM Persistable.
Now, when I select “Update to code” nothing is done. There is no @Entity added nor a “import org.hibernate.annotations.Entity;”.
Either I’m missing something or I’m doing something wrong.
Also, if I have a new UML class diagram with only a class name plus a stereo type (no corresponding, existing file), no java file is generated if I select “update to code”.
(Above when using SDE for Eclipse on Vista)
When I manually add @Entity tags to the classes, then select “reverse code” and immediately select “generate code”, all object relations (even between two persistent classes) get added @Transient annotations which were not there before (wrongly, of course) (this is when using VP UML Professional on OSX)
Could anyone help me with this issue?
Thanks, Metron
