Hello folks,
i’ve read the other linux related topics here in this forum but i don’t know, how to go on.
i ve downloaded VP(Filename: VP_Suite_Linux_NoInstall_3_2_sp1_20080417.tar.gz). I started the bash script ./bin/VP_Suite to set it up. That worked fine. No error occured. But when i try to start vp using ./launcher/run_vpuml the programm freezes after selecting a workspace and creating a log file called ~/vp.log. The log file contains:
[Wed May 21 19:00:17 CEST 2008] [message] [Wed May 21 19:00:17 CEST 2008]: Start Visual Paradigm for UML Standard Edition [VP-UML SE]: 6.2 (sp1_20080417)
My machine runs under ubuntu linux 8.04-x86_64 and compiz is not enabled. I tested the vp setup on a other machine(ubuntu 7.10) and everything works fine.
btw:
- the file ./bin/VP_Suite died with an error message:
… unpack200 not found
(or somenthing like that) because the java vm was not found, so i created an symlink called jre to my java vm base directory. eclipse needs this hack too… g - excuse me - my english isn’t very well…
greets
fe
