I want to write in my document generate with report writer this property:
is this code correct???
I ask this question, because the property name and modelType are written in the document, but the property begin and “end” are not written!
I hope to receve the correct code!!!
I attach two image with the problem!
tks
Hi user,
Thanks for your post. I’ve forwarded the issue to our engineers to follow-up, and I’ll keep you informed for any news on this issue.
Hi user,
For the problem of not showing Begins and Ends on the report, it should because you tried to get “element” as string. Do you actually want to get the name of the from/to model of the ExceptionHandler?
If so, you should get “name” of or >ToEnd>
P.S.: and in is the from/to model.
Please find a sample attached below, you can get the name, effect (or other properties) from the from/to model of exception handler.
Hope this helps. If there is any further inquiry, please feel free to contact me.
ExceptionHandlers.xml
thanks
Now, It’s Work
Hi user,
You are welcome. Should you need any help, please feel free to contact me.
