For complex diagrams (particularly in overview diagrams) the resolution in the HTML, PDF and Word reports leaves much to be desired. Is it possible to enhance the resolution or to change the format (e.g. svg)?
Thank you for your help.
Roland
Roland
Hi Roland,
Not all browsers support SVG very well. Some browsers even do not support SVG/ I’ve prepared a sample for you. You may try with different browsers. If you use I.E. without installing any external plugin, it will prints the text on the screen instead of rendering it as image.
http://files3.visual-paradigm.com/200710/Jick/sample_report/index.html
Hello Jick
Thank you a lot for the example. Does that work also for Word or PDF Reports and where can I select this option?
Roland
FYI, SVG is being dropped by Adobe, so will not be supported sometime in 2008.
Hello Roland,
Actually, there are limitation for SVG. The most important one is it cannot handle static image user import into VP. Therefore, we would not consider at the moment. Sorry about this.
Hello Jick
So I take note of the circumstance, that it is not possible to create reports including diagrams with a higher resolution as given by default.
Thanks all for the feedback.
Best regards
Roland
