Hi all,
I downloaded the trail version of VP to test. I’m “attempting” to reverse engineer my Java code to generate a sequence diagram but every time I attempt it, I get a white box and the program crashes.
Is this a known fault?
Regards,
Jim
Hi all,
Regards,
Jim
Hello Jim,
This sounds very abnormal. Would you mind send me the following logs to have a look?
Look forward to hear from you.
Rain Wong
Hi Jim,
Thank you for your post. Other than vpupdate.log, do you see any other .log files inside the bin folder of VP-UML installation directory? The filename should have a name in this pattern: hs_err_pid%p.log (so similar)
If yes, please also upload them here. Thank you in advance!
Hi Jick,
Sorry for the late reply. I’m afraid I can’t see any other logs. I currently have in the bin folder;
