Please help me, I’ve just messed up with my GUI. From the menu, I chose Help/Customizing UI… then selected all the elements to hide. And now, I can not get access to that option anymore to restore my GUI back. I can’t use no shortcuts to open the menu, and wonder if there is a file to modify manually?
You can simply start the application with a new workspace to overcome this problem. The application should prompt you to select the workspace when it start. And if you specified the default workspace, then you can simply remove the .vpworkspaceinfo file under %VP Suite Installation directory%/bin folder to clear the setting.
Hello Rain,
I did try changing the workspace but it doesn’t work. I even created a new folder to be my new workspace, the application still got no menus… I couldn’t do nothing.
Thanks for your help.
Regards
BUI
