I’m having an issue with the evaluation version of VP-UML (EE).
Using Oracle 9i
We have a number of Oracle schemas with various tables setup in them, some tables have cross schema references.
I’m trying to reverse database (from the ORM menu), however the cross schema references are lost, infact worse than that, if a column is foreign key from a different schema VP seems to drop that column all together.
The other issue I am having is sometimes VP will not display the table listing on the second page of reverse database. It says the correct number of tables are there, and if I just click on next it generates an ERD from them, but I cannot select which tables I want on the page.
