I’d like to generate UML class diagram from source code. I clicked on a package -> SDE EE-IJ -> Update to SDE EE-IJ. I had then a popup “synchronizing”. Then nothing appear. Where is the class diagram.
Another issue
*.vpd and *.vpp don’t seem to be associated with a registered file type within IntelliJ. How can I open them?
Please note that the .vpd and .vpp is not associated with the IntelliJ. The .vpd file is used to contain some diagram information. User shouldn’t open this file directly. The .vpp file is the project file contains all the UML models and diagrams. After you have create a UML project inside your IntelliJ project (i.e., Open SDE EE-IJ), then this file will be created. This file will be opened when you open the UML model inside IntelliJ.
