SDE professional 4.0 (Build 20070220)
eclipse 3.2
jdk1.5.07
i am having enormous problems round tripping with SDE.
am using the ‘model->update code’ or force ‘model->update code’.
I am getting large number of duplicate methods in a dervied class. Yet in the UML model there are no duplicates.
I have spent days ont he is round tripping and still haveing enormous problem forward engineering then reverse engineer using the update code/update model mechanism.
I have read the docs but it sheds no light on this problem.
Could you send us your Eclipse workspace for identifying the problem? If this is not possible, are you able to reproduce the problem with a sample project?
By the way, 20070220 is a fairly old release. I recommend you run the updater to advance to the latest release. You can find the updater inside %VP-Suite-Install-Dir%/bin
I guess that you are not using Service Pack 1. As I know, cross version (even minor version) upgrade is not allowed by VP Update. Could you download the latest release, and reinstall by overwriting the current one?
