I use the plug in manager to download and install SDE, now it says it got installed, but where to start it? I can’t find any menu entries about SDE, any idea? Thanks.
Angelo :-o
Angelo :-o
no one knows or care to give me a hint? time to go to ArgoUML.
Dear angelochen960,
We are sorry that currently we do not support IntelliJ IDEA 7.0. The IntelliJ IDEA 7.0 will be supported in our next release. I can send you the early access build if you are interested to have a try. If you require any further information, please do not hesitate to contact me again.
Rain
thanks, is there a stand alone community version? I was trying to find it out in the download area, and found nothing.
Is it possible to get a trial of a more feature packed version?
Actually all products and edition are can be found in the VP Suite installer. You can specify the product and edition during installation. If you want to switch the edition of the installed software, please visit
Rain
Where do I download the version compatible with IntelliJ 7?
What is the status of the final release for this?
The IntelliJ IDEA 7 is already supported in latest VP Suite 3.2 (SDE 4.2). You can download the latest VP Suite 3.2 at the following link.
http://www.visual-paradigm.com/download/download.jsp?product=vpsuite
Rain Wong
I installed plugin of SDE 3.0 in IntelliJ.Idea 7.0.3 from Project Settings | Plugins but I don’t see any many item I can start with.
Hi janod,
Thanks for your post. Do you have an existing project in IntelliJ IDEA?
In order to startup SDE, you need to have an existing project in IntelliJ IDEA first, then right-click on the project and select SDE CE-IJ > Open SDE CE-IJ in the popup menu (you can refer to the attached image).
If there are any inquiries, please do not hesitate to ask.
I don’t have sde in menu still. Only if I download plugin from your web and install it separately.
But if I install plugin directly from IntelliJ Idea, there is no menu on right click.
Hi janod,
Thanks for replying. I suspect that the plugin in IntelliJ is outdated. Please uninstaller all VP plugins in your IntelliJ, and download the VP software from the Download site of our web site (http://www.visual-paradigm.com/download/). Then install SDE for IntelliJ to your machine and follow the steps I told you before to startup SDE for IntelliJ.
If you get any problems, please let me know.
