OS: SuSE 9.1
Sun Jre 1_4_2_04
./sdesejb_20040414.bin
reports
Preparing to install…
Extracting the installation resources from the installer archive…
Configuring the installer for this system’s environment…
Launching installer…
Invocation of this Java Application has caused an InvocationTargetException. This application will now exit. (LAX)
Stack Trace:
java.lang.NoClassDefFoundError
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:141)
at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEnvironment.java:62)
at java.awt.Window.init(Window.java:231)
at java.awt.Window.(Window.java:275)
at java.awt.Frame.(Frame.java:401)
at java.awt.Frame.(Frame.java:366)
at com.zerog.ia.installer.Main.d(DashoA8113)
at com.zerog.ia.installer.Main.a(DashoA8113)
at com.zerog.ia.installer.Main.main(DashoA8113)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at com.zerog.lax.LAX.launch(DashoA8113)
at com.zerog.lax.LAX.main(DashoA8113)
This Application has Unexpectedly Quit: Invocation of this Java Application has caused an InvocationTargetException. This application will now exit. (LAX)
I got the same issue. I solved it by running the the installation script using a UNIX console window. For example, Solaris is:
#sh ./XXX.bin -i console
Your problem is mostly caused by the installation software is failing to detect and load a graphic interface => Then complete your unix script by the command -i console
Please let me know once you have tried my suggestion.
mel@mels-dell:~/paccketti/binari$ ./sdecenb_20040705.bin -i console
Stack Trace:
java.lang.IllegalAccessError: com/zerog/ia/installer/util/ClassInfoManager$InfoPiece.
at ZeroGt.a (DashoA8113)
at com.zerog.ia.installer.Main.b (DashoA8113)
at com.zerog.ia.installer.Main.a (DashoA8113)
at com.zerog.ia.installer.Main.main (DashoA8113)
at java.lang.reflect.Method.invoke0 (Method.java)
at java.lang.reflect.Method.invoke (Method.java:255)
at com.zerog.lax.LAX.launch (DashoA8113)
at com.zerog.lax.LAX.main (DashoA8113)
This Java Application has encountered an unexpected error and will now exit. (LAX)
Stack Trace:
java.lang.NoClassDefFoundError: javax/swing/JDialog
