I have a model with several sequence diagrams in several subpackages. For each of these diagrams, a default frame is created with the same name, in the same package as the diagram.
Each time I open the model, it creates an additional empty frame for each sequence diagram in the model. These frames are empty and located on the root of the model.
If I delete them, they come back the next time I open the model.
Thanks for reporting this bug, and sorry for any inconveniences it may cause you. I will ask our engineers to fix it up. Once there is any progress, I will post here.
Certainly. Please follow the steps stated in the page I posted above to apply vpplatform.jar to the SDE. If you have run that already, SDE should have the hotfix applied.
Build 20060611 is deployed. Please perform an update to update the hotfix to a complete release. You can update through the updater at $vp-suite-install-dir/bin
