Jick,
We have a big problem. It seems like a stale objects. In Hibernate dcumentation I found the following:
In a three tiered architecture, consider using SaveOrUpdate().
When using a distributed architecture, you could pass persistent objects loaded in the middle tier to and from the user interface tier. Use a new session to service each request.
In a two tiered architecture, consider using session disconnection.
Database Transactions have to be as short as possible for best scalability. However, it is often neccessary to implement long running Application Transactions, a single unit-of-work from the point of view of a user. This Application Transaction might span several client requests and response cycles. Either use Detached Objects or, in two tiered architectures, simply disconnect the NHibernate Session from the ADO.NET connection and reconnect it for each subsequent request. Never use a single Session for more than one Application Transaction usecase, otherwise, you will run into stale data
Then they promote the following pattern:
ISession session;
ITransaction tx;
try
session = factory.OpenSession();
tx = session.BeginTransaction();
// do database work
tx.Commit();
session.Close();
catch (Exception ex)
tx.Rollback();
session.Close();
// further exception handling
We would like to experiment with sessions, but possibilities in the code generated by VP seem very limited. Can you help us with this, please? We are really stuck at this moment.
Cheers,
Tadeusz
