Startup error
Hi all,
 I have downloaded "Business_Process_Visual_ARCHITECT_1.1" for evaluation. I was able to install it. But, when i try to start the launcher, it quits immediately. I have attached the error log. Thankyou for u r help....
Samrat
hs_err_pid7230.log
Hi Samrat,
Thank you for your post.
First, may I know if your Linux interface runs in German? If so, could you try run in English and let me know if this solves your problem?
If this does not help, please try the following steps:
  1. Switch on the console
  2. Direct to $bpva-install-folder
  3. Enter the following script:
/usr/lib/j2sdk1.5-sun/bin/java -Xms128m -Xmx512m "-Dsun.java2d.noddraw=true" -cp ".:../lib/vpplatform.jar:../lib/jniwrap.jar:../lib/jhall.jar:../lib/vpuml-help.jar:../lib/winpack.jar:../lib/vpupdate.jar:../lib/openapi.jar:../ormlib/orm.jar:../lib/jh.jar:../lib/lib01.jar:../lib/lib02.jar:../lib/lib03.jar:../lib/lib04.jar:../lib/lib05.jar:../lib/lib06.jar:../lib/lib07.jar:../lib/lib08.jar:../lib/lib09.jar:../lib/lib10.jar" RV
This runs BP-VA with your JDK. Let see if this solves your problem.
If you have time, please let me know about the result. Thank you!
