When first installing or opening any of the VP tools there is a window that asks about trial, subscription, etc. This window behaves strangely in that in OSX it seems to be treated as if it was 1920x1080 or so. The three circles in the upper left of a OSX application are shown but are disconnected and floating in the middle of nowhere.
With Mavericks, each monitor is treated as its own separate domain. So what happens is that because the window is so large, but the visible portion is very small, the overlap is not shown on the next monitor. This is a change with Mavericks. So the only thing visible to the user are the 3 circles if you happen to spot them. Otherwise you cannot see the window at all if your left most monitor is vertical.
