Making a sub-process of a group a number of tasks, gateways and process flows gives me a problem:
All the process flows are disappeared
That makes reorganising the process diagram a pain in the but.
Addition to the previous message.
When I start redrawing the process flows they appear as double lines.
I turned out that the original flows became visible?
How is that possible and how can I avoid it :?
Another addition:
The flows become visible after clicking Layout/Route Connectors.
The problem then is that the gateways change size and the connectors change position which give the decision in the gateway a totally different meaning and outcome
Hi Elbert,
I tried drawing a Group with several tasks, gateway and process flow in it, and form a subprocess diagram. But nothing seems strange. I captured a movie to show you what I have done:
http://files4.visual-paradigm.com/200609/Jick/forming-subprocess-diagram-from-group.htm
Could you provide me with more hints? Maybe steps in point form will be helpful. Thank you very much.
Hi Jick,
I did the following:
1: New BP Diagram
2: Add start event and draw 3 steps with connectors and end event.
3: With the mouse pointer draw a selection rectangle
4: Right click on one of the steps and select “Form Sub Process Diagram”
Then the 3 steps will be visible in the lower level diagram. Without the connectors.
The connectors will be visible after clicking Layout/ Route Connectors.
Before I did the route action I drew new connectors. That’s why they appeared double after I did click (for some reason) on Layout/ Route Connectors
regards
Elbert
Hi Elbert,
Your steps are very helpful. I am able to repeat the problem now. I am going to ask our engineers to fix this problem, and will post there result here afterwards.
Hi Elbert,
Here is the download link of the hotfix to the problem you mentioned in this post.
http://files3.visual-paradigm.com/200610/Hotfix/5-3-2_sp2_20061014h/vpplatform.jar
The following page teaches you how to apply the hotfix:
http://resource.visual-paradigm.com/tips_and_tricks/general/replacing_hot_fix.html
I will post again when a complete release is ready.
Dear Elbert,
A new build of VP Suite is ready. Since you have been asked to apply a hotfix, please run the updater inside the vp-suite-install-dir/bin to upgrade the tool to the latest release.
Please feel free to let me know if there is a question.
