In the “VP Suite 3.1” folder I cannot see any folder folder matching the description you have given. There is no subversion folder. There are many config folders. What is the name of the config file? and is it in a different location for the version I have?
Why do I have to specify login data in this config file? After all, it’s different for each server I use.
I tried omitting the login part and instead using the user/password field in the “Login to the Teamwork Server” dialog window, but it doesn’t work. The process that starts is: "D:/Programs/Putty/plink.exe -ssh -batch server.name svnserve -t"
If I include my username in the repository path like svn+ssh://login@svn.server.xx/…/ Then it’s “D:/Programs/Putty/plink.exe -ssh -batch login@server.name svnserve -t” But password is still missing. How are the 2 values of the dialog field handed over to the process? At the moment it only works by hardcoding it into the config file as a workaround.
