Hi all,
when I try to define an input parameter with generic type (as in Java language) within a method, VP displays the following message:
CANNOT CONFIRM EDIT BECAUSE THERE ARE SYNTAX ERRORS IN TEXT
What I’m trying to draw is a class with a method like the following:
Your problem is caused by you have swapped the position of the parameter name and type. It should be +operation2(params : Map<String, String>) : List. Feel free to contact me if you require any further information.
