Hello there,
I’ve figured out that there are still problems using the Teamwork client with Subversion in combination with https and self signed ssl certificates. When the server certificate is untrusted and unknown to your local subversion client, login to the repository is not possible. It fails with the dialog box “login failed”. To afford the login you have first to accept the certificate permanetly with a other client e.g. doing an svn ls https://server/reopos.
vp.log claims with follwing error:
Fri Jul 27 09:15:52 CEST 2007] [error] ExecuteOutput err svn: PROPFIND Anfrage fehlgeschlagen auf ‘/svn/vpptest’
[Fri Jul 27 09:15:52 CEST 2007] [error] ExecuteOutput err svn: PROPFIND von ‘/svn/vpptest’: Server certificate verification failed: certificate issued for a different hostname, issuer is not trusted (https://subversion)
[Fri Jul 27 09:15:52 CEST 2007] [warning] login svn fail , errMsg : null
An other thing that annoys to me is that the “login failed” messagebox appears on all errors that can occurence when you login and misspelled one of the something or a problem manners:
- wrong server name
- wrong path to repos
- wrong username and password
- unknown / untrusted server certificate (see above)
For an normal user the currently messagebox is dowdy because he have no information about the exact problem. Only vp.log shows an usefull information what went wrong (see attached log).
I would be nice when you fix this with better error messages in the message box and the possibility to accept ssl certificates.
Greets
Frank
[Fri Jul 27 09:16:50 CEST 2007] [message] — loadClientInfo — /root/vpworkspace/teamwork_client
[Fri Jul 27 09:17:04 CEST 2007] [error] ExecuteOutput err svn: PROPFIND Anfrage fehlgeschlagen auf ‘/svn/vpptest’
[Fri Jul 27 09:17:04 CEST 2007] [error] ExecuteOutput err svn: PROPFIND von ‘/svn/vpptest’: Server certificate verification failed: issuer is not trusted (https://server241vx)
[Fri Jul 27 09:17:04 CEST 2007] [warning] login svn fail , errMsg : null
[Fri Jul 27 09:17:52 CEST 2007] [error] ExecuteOutput err svn: PROPFIND Anfrage fehlgeschlagen auf ‘/svn/vpptest’
[Fri Jul 27 09:17:52 CEST 2007] [error] ExecuteOutput err svn: PROPFIND von ‘/svn/vpptest’: Could not resolve hostname `server241x’: Host not found (https://server241x)
[Fri Jul 27 09:17:52 CEST 2007] [warning] login svn fail , errMsg : null
[Fri Jul 27 09:18:24 CEST 2007] [error] ExecuteOutput err svn: PROPFIND Anfrage fehlgeschlagen auf ‘/svn/vpptes’
[Fri Jul 27 09:18:24 CEST 2007] [error] ExecuteOutput err svn: PROPFIND von ‘/svn/vpptes’: 403 Forbidden (https://server241vx)
[Fri Jul 27 09:18:24 CEST 2007] [warning] login svn fail , errMsg : null
[Fri Jul 27 10:45:24 CEST 2007] [error] ExecuteOutput err svn: PROPFIND Anfrage fehlgeschlagen auf ‘/svn/vpptest’
[Fri Jul 27 10:45:24 CEST 2007] [error] ExecuteOutput err svn: PROPFIND von ‘/svn/vpptest’: Autorisierung fehlgeschlagen (https://server241vx)
[Fri Jul 27 10:45:24 CEST 2007] [warning] login svn fail , errMsg : null
