I have just installed an update of VP 4.0 and suddenly I cannot use stereotypes on my UML classes since the shape of the class changes to a circle?
If I leave the class without a stereotype I do not have an issue, however if I try to add a stereotype if completely messes up my diagram. Additionally, in one of my files the diagram tab disappeared completely!
When is this issue going to be fixed?
I have tried to uninstall and reinstalling VP however the problem was not fixed.
Thank you
Hi user,
Thanks for your post. Would you mind to attach your project file and vp.log file (can be found from VPSuite/bin folder), or send them to lilian.wong@visual-paradigm.com for investigation? Thanks in advance!
And you mentioned that “in one of my files the diagram tab disappeared completely”, do you mean the diagram is closed?
If so, you can open the Diagram Navigator (if you do not see it, please select View > Panes > Diagram Navigator), expand diagram node and double-click on the diagram name for opening the diagram again?
Look forward to hearing your response.
