It’s possible to use the Community Edition to draw only UML diagram (class diagram) without generate java source code ?
Thank You
Roberto
Thank You
Roberto
Dear Roberto,
Sure. If you select to create a new class diagram, it will not generate Java code by default. It will generate Java code only if you select to create a class diagram with real-time code synchronization or you have configured the Java code engine set.
Regards,
Antony.
