Unable to reverse database, MSSQL 2005
on the second step after entering all information test connection failed, see pics
Hi Alex,
It looks like the adapter file is incorrect. Could you press the Down arrow to let us download for you? The one we download should work without problem.
downloaded and got another error
Hi Alex,
almws\sqlexpress does not appear to be a correct Host name… Could you make sure a correct one is entered? Alternatively, you can specify an IP address to be the host name.
Ok.
How to connect to diffrent instances of the MS SQLServer on the same host?
Hi Alex,
I believe that you can connect to different instances by specifying the different ports that connects to different instances.
now it works, thank you!
My pleasure :slight_smile: :slight_smile: :slight_smile: :slight_smile:
