Currently, I am using Eclipse 3.7.1, and have attached the log file found in the Eclipse Platform Installation Details.
After following the instructions. I have opened eclipse and tried right clicking my projects. The new VP-UML Project menu option isnt there. I cannot do a round trip between VP UML 8.3 and Eclipse.
As I know the problem was fixed. Please run the update program that can be found in %VP-SUITE-INSTALL-DIR%\bin to advance to the latest hotfix release for a fix.
Feel free to contact us again if you have any questions.
I do have the same issue. I run Mac OS X 10.8.2 with the latest Eclipse Juno build and Visual Paradigm CE 10. Installing the IDE integration just worked with ease. But i can’t start the VP-plugin from Eclipse, it just shows the VP Load Screen (red one with logo and stuff). Please help me out with that!
i just followed your link you sent me the other day to install the latest patch (sp1_20121110dt) for VP CE 10. The problem i hab before installing the patch was posted ahead. Now that i have installed the patch and want to export a Java project to VP_UML, it just does nothing but getting stuck on Eclipse (which ends up with Eclipse being force closed!). Do you have any solutions for that issue?
[quote=Anonymous][quote=Rain]Can you also send use the eclipse log file to have a look? You can find it inside %eclipse_workspace%/.metadata/.log
Thanks.
Rain Wong[/quote]
Hi there,
it seems like a long time ago that I sent you my error logs. But I haven’t received any answer related to this issue i was talking about earlier. Is there any new stuff I can deal with to solve this problem?
Hi, i
have the same Problem.
I installed the Plugin in Eclipse Juno and if i create a new Java Project in Eclipse Juno the Context Menu for
Open VP-UML Project
Update VP-UML Project
is disabled.
If i select the VP-UML Project the New VP-UML Project the Spin Ball comes up and Eclipse Hangs up.
Mac OS X 10.8.3
JDK
java version "1.7.0_17"
Java™ SE Runtime Environment (build 1.7.0_17-b02)
Java HotSpot™ 64-Bit Server VM (build 23.7-b01, mixed mode)
Eclipse
Eclipse for RCP and RAP Developers
Version: Juno Service Release 1
Build id: 20120920-0800
I have exactly the same problem as lkluge.
Does anybody know how to solve this problem?
Is it an installation problem? I updated Eclipse and re-installed the plugin, but the problem remained.
Can you send me the vpuml.log file under %user_home%/visualparadigm folder to have a look? BTW, can you try to run the Eclipse with JDK 1.6 and see will it work?
Do you have any news on this issue? The Eclipse integration is not working with the MacOS even after the latest update or when using JDK 6.0. Does it work at your lab? Any idea of what can be wrong?
