Regarding “Use Case Details” from the context menu for a use case.
Is there a way to rename a Use Case Detail, or have it match the name of the parent use case?
When viewing the Window menu “Switch To Diagram” dialog, the Use Case Detail is simply listed as “Use Case Details1”, “Use Case Details2”, etc. Having the name of the parent use case, or the name given in the Use Case Details screen would be more useful.
The Use Case Details screen does not allow pasting text with Command-V on the Macintosh.
This is true of the Info and Description tabs.
Command-C does copy text
Command-X does cut text
Command-V does not paste text
PC keys do function here, so there is a work around.
Control-C does copy text
Control-X does cut text
Control-V does paste text
Another common Mac keystroke that does not work as expected is Command-Z for undo. Control-Z does work, but again this is not what is expected on the Mac.
This is in contrast to the Textual Analysis editor where only the Mac standard keys work (but there is no undo).
It would be nice if all the standard Macintosh keys worked as expected.
Restart the application
Note:
Sorry for missing the other question. We will not support renaming use case detail in the near future. But we will fix this problem by forcing the use case detail to name as $use-case-name Details. This will, in most cases, help identifying which use case a use case details tab belongs to. The fix will be available in Service Pack 2, and hope to release that in the next week.
Remember the fix of using use case name as the name of use case detail? This fix is now ready in Service Pack 2, which was released last Saturday. Since you were asked to use a patch, I would like to suggest you upgrade to the latest version, which is more stable than the patch.
To upgrade, please run the product updater inside the bin folder of VP Suite installation directory.
