hi,
i just tried to copy a text like:
• aasdfkjalösdfjöalskfdklöj)
aslkfjaslöfjdlöaskjfdasdfasdfasdfasdfklökjasdfljkasdlfjasdlöfjkaslfjdaslödfjkm asdfjaölsfjdöalskjfdlöaksjfd
asjdfalöskfjdalöskfjdölaskfjdöalskjfdalöskfjdalösfjdalskfjdaslökfjdaslökfjdder Verarbeitung wird nicht zwischen physischen und nicht physischen unterschieden.
from MS Word to a Agilian 1.2 (sp1):: Spezification Use-Case:: Dokumentation.
On Pasting (Ctrl-V) Agilian no longer responded. The task java.exe was constantly using 50 % CPU.
I’ve attached the log.
regs
sebastian
Crashlog.no_ext
Hi Sebastian,
Thanks for your post.
Can I schedule an online meeting with you to take a look at this problem? The online meeting will be held over a secure connection. I will be able to see your screen and may need to control it with your approval. If you can join the meeting, please let me know when you will be available and what time zone are you in.
Hi Lilian,
do I need a special software for the meeting?
Timezone is CET
regs
sebastian
Hi Sebastian,
Thanks for replying. Could you please also tell me when (both date and time) you will be available to join the meeting? Thanks!
FYI, you just need to download and execute a small applet to start the meeting.
