I am using an evaluation version of the personal edition. Often (but not always) VP will hang when I try to delete a class from a class diagram. Usually the class is referenced in another class diagram. I have to use the Windows Task Manager to end the VP application.
I am enclosing a log from today’s session for you to review.
Thank you for the bug report. I am sorry for any inconvenience the problem may cause you.
Is this problem repeatable by following a set of steps? If so, could you please let me know how to repeat it? Apart from this, could you please send me also your project file through private message? Thank you very much.
I will now forward your case to our engineers for testing.
Usually, we only send hotfix to user(s) who reported the bug that is fixed in the hotfix release. But do not worry, when a hotfix is available, this means that a complete build will available very soon (usually half to one working day after the release of hotfix). So you may try updating VP Suite tomorrow, you should be able to advance to the next build.
