I m using visual paradigm uml entreprise edition.
I create a class diagram with two class car and exceptioncar.
car have a method run throws an exceptioncar.
When i use the tools generate word report, i have the Raised Exceptions in the operations chapter.
But when i use the tools report writer, i don’t have the Raised Exceptions.
Is it a bug ? what is the method to insert the Raised Exceptions ?
VP_Suite_Windows_3_4_sp1_20081230.exe should correct this problem.
but i ve always this problem.
Hi user,
Thanks for your post. Please open the Model Explorer in the Report Writer, select the class and then the operation, then you can drag “Raised Exceptions” template to the report (see image below).
[quote=LilianWong]Hi user,
Lilian Wong[/quote]
Thanks for your response, it s work fine
Hi user,
You are welcome. Should you have any inquiry again, please feel free to contact me.
[quote=Anonymous]I m using visual paradigm uml entreprise edition.
Thanks[/quote]
