Greetings. I am attempting to evaluate the Professional version of VP under Netbeans 4.0. The package installed and accepted the evaluation key without any problems. However, when I attempt to start VP (Tools->Start VP-UML PE) Netbeans reports a NullPointerException. All that VP ever does is ask for a project path, which I set to the default.
Below are the vp.log and the netbeans log. Any information on how to fix this problem would be appreciated. Thanks.
Netbeans messages.log:
Log Session: Monday, March 28, 2005 8:49:01 AM GMT-05:00
System Info:
Product Version = NetBeans IDE 4.0 (Build 200412081800)
Operating System = Windows XP version 5.1 running on x86
Java; VM; Vendor = 1.5.0_01; Java HotSpot™ Client VM 1.5.0_01-b08; Sun Microsystems Inc.
Java Home = C:\java\jdk1.5.0_01\jre
System Locale; Encod. = en_US (nb); Cp1252
Home Dir; Current Dir = C:\Documents and Settings\aaron.gage; C:\java\netbeans-4.0
IDE Install; User Dir = C:\java\netbeans-4.0\platform4; C:\Documents and Settings\aaron.gage.netbeans\4.0
CLASSPATH = C:\java\netbeans-4.0\platform4\lib\boot.jar;C:\java\netbeans-4.0\platform4\lib\JoeDriver.jar;C:\java\jdk1.5.0_01\lib\dt.jar;C:\java\jdk1.5.0_01\lib\tools.jar
Boot & ext classpath = C:\java\jdk1.5.0_01\jre\lib\rt.jar;C:\java\jdk1.5.0_01\jre\lib\i18n.jar;C:\java\jdk1.5.0_01\jre\lib\sunrsasign.jar;C:\java\jdk1.5.0_01\jre\lib\jsse.jar;C:\java\jdk1.5.0_01\jre\lib\jce.jar;C:\java\jdk1.5.0_01\jre\lib\charsets.jar;C:\java\jdk1.5.0_01\jre\classes;C:\java\jdk1.5.0_01\jre\lib\ext\dnsns.jar;C:\java\jdk1.5.0_01\jre\lib\ext\localedata.jar;C:\java\jdk1.5.0_01\jre\lib\ext\sunjce_provider.jar;C:\java\jdk1.5.0_01\jre\lib\ext\sunpkcs11.jar
Dynamic classpath = C:\java\netbeans-4.0\platform4\core\core.jar;C:\java\netbeans-4.0\platform4\core\openide-loaders.jar;C:\java\netbeans-4.0\platform4\core\openide.jar;C:\java\netbeans-4.0\platform4\core\org-netbeans-swing-plaf.jar;C:\java\netbeans-4.0\platform4\core\updater.jar;C:\java\netbeans-4.0\nb4.0\core\org-netbeans-upgrade.jar;C:\java\netbeans-4.0\nb4.0\core\locale\core_nb.jar;C:\java\netbeans-4.0\ide4\core\org-netbeans-modules-utilities-cli.jar
[org.netbeans.core.modules #4] Warning - had to upgrade dependencies for module com.vp.vpsde.nb: added = [module org.openide.src > 1.3] removed = [module org.openide.src > 1.0]; details: [Java Comparators separation (#40945): http://www.netbeans.org/download/dev/javadoc/OpenAPIs/org/openide/doc-files/upgrade.html#4.0-javacomparators]
[org.netbeans.core.modules #4] WARNING: Class-Path value …/lib/vpsdenb/vpsdenblib.jar from C:\java\netbeans-4.0\ide4\modules\com-vp-vpsde-nb.jar is illegal according to the Java Extension Mechanism: must be relative and not move up directories
[org.netbeans.core.modules #4] WARNING: Class-Path value …/lib/vpsdenb/orm.jar from C:\java\netbeans-4.0\ide4\modules\com-vp-vpsde-nb.jar is illegal according to the Java Extension Mechanism: must be relative and not move up directories
[org.netbeans.core.modules #4] WARNING: Class-Path value …/lib/vpsdenb/jniwrap.jar from C:\java\netbeans-4.0\ide4\modules\com-vp-vpsde-nb.jar is illegal according to the Java Extension Mechanism: must be relative and not move up directories
[org.netbeans.core.modules #4] WARNING: Class-Path value …/lib/vpsdenb/winpack.jar from C:\java\netbeans-4.0\ide4\modules\com-vp-vpsde-nb.jar is illegal according to the Java Extension Mechanism: must be relative and not move up directories
INFORMATIONAL *********** Exception occurred ************ at 8:49 AM on Mar 28, 2005
[catch]java.lang.IllegalStateException: Assertion failed. WindowsAPI is required to be called from AWT thread only, see http://www.netbeans.org/download/dev/javadoc/OpenAPIs/org/openide/doc-files/threading.html
at org.netbeans.core.windows.WindowManagerImpl.assertEventDispatchThreadWeak(WindowManagerImpl.java:1099)
at org.netbeans.core.windows.WindowManagerImpl.getMainWindow(WindowManagerImpl.java:114)
at v.vls.r(:221)
at v.vls.y(:274)
at v.llh.n(:153)
at v.mxv.run(:64)
at v.ifsh.d(:55)
at v.wia.run(:85)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
[catch] at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:234)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:163)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:157)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:149)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
VP’s vp.log:
No JNI Library 8
Turning on modules:
org.openide/1 [4.50.1 200412081800]
org.openide.loaders [4.17.1 200412081800]
org.openide.io [1.3.1 200412081800]
org.openide.execution [1.4.1 200412081800]
org.netbeans.core.output2/1 [1.1.1 200412081800]
org.netbeans.swing.plaf [1.1.1 200412081800]
org.netbeans.core/1 [1.26.1 200412081800]
org.netbeans.core.execution/1 [1.5.1 200412081800]
org.apache.tools.ant.module/3 [3.14.1 200412081800]
org.netbeans.api.java/1 [1.6.1 200412081800]
org.netbeans.modules.java.platform/0 [1.1.1 200412081800]
org.openide.src [1.4.1 200412081800]
org.netbeans.spi.viewmodel/1 [1.2.1 200412081800]
org.netbeans.api.debugger/1 [1.1.1 200412081800]
org.netbeans.api.debugger.jpda/1 [1.1.1 200412081800]
org.netbeans.modules.queries/0 [1.1.1 200412081800]
org.netbeans.modules.projectapi/0 [1.1.1 200412081800]
org.netbeans.modules.projectuiapi/0 [1.1.1 4.0.0 200412081800]
org.openidex.util/3 [3.4.1 200412081800]
org.netbeans.modules.project.ant/0 [1.1.1 200412081800]
org.netbeans.modules.project.libraries/0 [1.8.1 200412081800]
org.netbeans.modules.settings/1 [1.6.1 200412081800]
org.netbeans.swing.tabcontrol [1.1.1 200412081800]
org.netbeans.core.windows/2 [2.2.1 200412081800]
org.netbeans.core.ui/1 [1.5.1 200412081800]
org.netbeans.modules.masterfs/1 [1.3.1 200412081800]
org.netbeans.modules.projectui [1.1.1 200412081800]
javax.jmi.reflect/1 [1.2.1 200412081800]
javax.jmi.model/1 [1.2.1 200412081800]
org.netbeans.api.mdr/1 [0.987.1 200412081800]
org.netbeans.jmi.javamodel/1 [1.0.1 200412081800]
org.netbeans.modules.jmiutils/1 [0.85.1 release40]
org.netbeans.modules.mdr/1 [0.93.1 release40]
org.netbeans.modules.classfile/1 [1.13.1 200412081800]
org.netbeans.modules.javacore/1 [1.3.1 200412081800]
org.netbeans.modules.java/1 [1.18.1 1.0.0]
org.netbeans.modules.java.project/0 [1.1.1 0.1.1]
org.netbeans.modules.debugger.jpdaimpl/2 [1.12.1 200412081800]
org.netbeans.spi.debugger.ui/1 [2.4.1 200412081800]
org.netbeans.modules.debugger.jpda.ui/1 [1.1.1 200412081800]
org.netbeans.modules.debugger.jpda.ant [1.3.1 200412081800]
org.netbeans.modules.ant.browsetask [1.7.1 200412081800]
org.netbeans.modules.junit/2 [2.13.1 200412081800]
org.netbeans.modules.java.j2seproject [1.1.1 200412081800]
org.netbeans.libs.commons_logging/1 [1.0 1.0.4 200412081800]
org.netbeans.modules.servletapi24/1 [2.2.1 2.2.1 200412081800]
org.netbeans.libs.xerces/1 [1.5 2.6.2]
org.netbeans.modules.web.jspparser/2 [2.1.1 200412081800]
org.netbeans.api.web.webmodule [1.1.1 200412081800]
org.netbeans.modules.schema2beans/1 [1.10.1 200412081800]
org.netbeans.api.web.dd/1 [1.3.1 1.0]
org.netbeans.modules.j2eeapis/1 [1.2.1 200412081800]
org.netbeans.api.xml/1 [1.6 release40 200412081800]
org.netbeans.libs.j2eeeditor/1 [1.3.1 200412081800]
org.netbeans.modules.j2eeserver/3 [1.3.1 200412081800]
org.netbeans.modules.servletapi23/1 [1.6.1 200412081800]
org.netbeans.modules.xml.core/2 [1.4 release40 200412081800]
org.netbeans.modules.xml.catalog/2 [1.4 release40 200412081800]
org.netbeans.modules.editor.util/1 [1.1.1 200412081800]
org.netbeans.modules.editor.fold/1 [1.1.1 200412081800]
org.netbeans.modules.editor.lib/1 [1.1.1 200412081800]
org.netbeans.modules.editor/2 [1.16.1 200412081800]
org.netbeans.modules.xml.text/2 [1.4 release40 200412081800]
org.netbeans.modules.html/1 [1.14.1 200412081800]
org.netbeans.modules.web.core.syntax/1 [1.15.1 200412081800]
org.netbeans.modules.web.core/1 [1.19.1 200412081800]
org.netbeans.modules.web.project [1.2.1 200412081800]
org.netbeans.modules.servletapi/1 [1.5.1 200412081800]
org.netbeans.modules.httpserver/2 [2.0.1 2.0-release40]
org.netbeans.modules.css/2 [1.4 release40 200412081800]
org.netbeans.modules.xml.tax/2 [1.4 release40 200412081800]
org.netbeans.modules.jemmy.idemodule/2 [2.2.4.15 200412081800]
org.netbeans.modules.diff/1 [1.9.1 promotionD 200412081800]
org.netbeans.modules.javahelp/1 [2.4.1 200412081800]
org.netbeans.modules.jemmysupport/1 [1.16 200412081800]
com.vp.vpsde.nb/1 [ 200409220845]
org.netbeans.modules.favorites/1 [1.7.1 200412081800]
org.netbeans.modules.vcscore/1 [1.11.1.0.0.2 promotionD_Fixes1 041217]
org.netbeans.modules.vcs.advanced/1 [1.11.1.0.0.1 041217]
org.netbeans.modules.vcs.profiles.vss/1 [1.5.1 200412081800]
org.netbeans.modules.utilities/1 [1.17.1 200412081800]
org.netbeans.modules.xsl/1 [1.4 release40 200412081800]
org.netbeans.modules.web.jstl11/1 [2.2.1 2.2.1 200412081800]
org.netbeans.modules.extbrowser/1 [1.5.1 200412081800]
org.netbeans.modules.apisupport.ant [2.22.1 200412081800]
org.netbeans.modules.xml.tools/2 [1.4 release40 200412081800]
org.netbeans.modules.usersguide/1 [1.15.1 200412081800]
org.netbeans.core.multiview/1 [1.3 release40 200412081800]
org.netbeans.modules.form/2 [1.15.1 200412081800]
org.netbeans.lib.cvsclient/1 [1.10.1.0.0.1 050128]
org.netbeans.core.ide/1 [1.5.1 200412081800]
org.netbeans.tasklistapi/1 [1.14.5 5 200412081800]
org.netbeans.modules.tasklist.core/2 [1.31.510 10 200412081800]
org.netbeans.modules.suggestions_framework/2 [1.9.5106 6 200412081800]
org.netbeans.modules.tasklist.docscan/2 [1.17.51063 3 200412081800]
org.netbeans.modules.web.examples/1 [1.1.1 200412081800]
org.netbeans.modules.properties/1 [1.13.1 200412081800]
org.netbeans.modules.properties.syntax/1 [1.12.1 200412081800]
org.netbeans.modules.refactoring/1 [1.0.1 200412081800]
org.netbeans.modules.apisupport.project [1.0.1 200412081800]
org.netbeans.modules.nbjunit/1 [1.16 200412081800]
org.netbeans.modules.beans/1 [1.13.1 200412081800]
org.netbeans.modules.autoupdate/1 [2.11.1 200412081800]
org.netbeans.modules.updatecenters/1 [1.2.1 200412081800]
org.netbeans.modules.clazz/1 [1.15.1 200412081800]
org.netbeans.upgrader [4.1.1 200412081800]
org.netbeans.modules.vcs.profiles.cvsprofiles/1 [1.5.1 200412081800]
org.netbeans.modules.jellytools/2 [2.3.13 200412081800]
org.netbeans.modules.i18n/1 [1.16.1 200412081800]
org.netbeans.modules.i18n.form/2 [1.14.1 200412081800]
org.netbeans.modules.javadoc/1 [1.13.1 200412081800]
org.netbeans.modules.ant.grammar/1 [1.8 200412081800]
org.netbeans.modules.j2ee.ant [1.2.1 200412081800]
org.netbeans.modules.db/1 [1.10.1 release40 200412081800]
org.netbeans.modules.java.j2seplatform/1 [1.1.1 200412081800]
org.netbeans.modules.java.examples/1 [1.1.1 200412081800]
org.netbeans.modules.utilities.project/1 [1.1.1 200412081800]
org.netbeans.modules.welcome/1 [1.6.1 200412081800]
org.netbeans.modules.tomcat5/1 [1.2.1 200412081800]
org.netbeans.modules.tomcat5.bundled/1 [1.2.1 200412081800]
org.netbeans.modules.xml.schema/1 [1.4 release40 200412081800]
org.netbeans.modules.web.monitor/1 [1.11.1 200412081800]
org.netbeans.modules.web.debug/1 [2.3.1 200412081800]
org.netbeans.modules.image/1 [1.13.1 200412081800]
org.netbeans.modules.ant.freeform [1.1.1 200412081800]
org.netbeans.modules.vcs.profiles.pvcs/1 [1.5.1 200412081800]
Using org.netbeans.jemmy.drivers.DefaultDriverInstaller driver installer
Cannot read Product and Edition
No JNI Library 8
