I’m trying to install VP Suite 2.1, and the installer keeps failing. After I select the installation file, it reports a divide by 0 error. If I look at the generated log file, I see the following exception stack trace:
Exception:
java.lang.ArithmeticException: / by zero
at com.install4j.runtime.installer.Installer.doStandardInstallation(Unknown Source)
at com.install4j.runtime.installer.Installer.doInstallation(Unknown Source)
at com.install4j.runtime.installer.Installer.install(Unknown Source)
at com.install4j.runtime.installer.frontend.screens.InstallationScreen$1.run(Unknown Source)
System properties:
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
exe4j.moduleName=/Users/tdean/Desktop/VP Suite 2.1 Installer.app
sun.boot.library.path=/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries
java.vm.version=1.5.0_05-43
awt.nativeDoubleBuffering=true
gopherProxySet=false
java.vm.vendor="Apple Computer, Inc."
java.vendor.url=http://apple.com/
proxyUser=
path.separator=:
java.vm.name=Java HotSpot(TM) Client VM
file.encoding.pkg=sun.io
user.country=US
sun.os.patch.level=unknown
java.vm.specification.name=Java Virtual Machine Specification
user.dir=/Users/tdean/Desktop/VP Suite 2.1 Installer.app/Contents/Resources/app
java.runtime.version=1.5.0_05-64
java.awt.graphicsenv=apple.awt.CGraphicsEnvironment
java.endorsed.dirs=/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home/lib/endorsed
os.arch=ppc
proxyPort=
java.io.tmpdir=/tmp
line.separator=
java.vm.specification.vendor=Sun Microsystems Inc.
os.name=Mac OS X
proxySet=false
sun.jnu.encoding=MacRoman
java.library.path=/Users/tdean/Desktop/VP Suite 2.1 Installer.app/Contents/Resources/Java:/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Resources:.:/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java
java.specification.name=Java Platform API Specification
java.class.version=49.0
sun.management.compiler=HotSpot Client Compiler
os.version=10.4.3
user.home=/Users/tdean
user.timezone=America/Chicago
java.awt.printerjob=apple.awt.CPrinterJob
file.encoding=MacRoman
java.specification.version=1.5
JFileChooser.appBundleIsTraversable=always
java.class.path=/Users/tdean/Desktop/VP Suite 2.1 Installer.app/Contents/Resources/app/.install4j/i4jruntime.jar:/Users/tdean/Desktop/VP Suite 2.1 Installer.app/Contents/Resources/app/user.jar
user.name=tdean
proxyHost=
java.vm.specification.version=1.0
java.home=/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home
sun.arch.data.model=32
user.language=en
java.specification.vendor=Sun Microsystems Inc.
awt.toolkit=apple.awt.CToolkit
java.vm.info=mixed mode
java.version=1.5.0_05
java.ext.dirs=/Library/Java/Extensions:/System/Library/Java/Extensions:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home/lib/ext
sun.boot.class.path=/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/classes.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/ui.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/laf.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/sunrsasign.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/jsse.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/jce.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/charsets.jar:/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Resources/LauncherSupport.jar
java.vendor=Apple Computer, Inc.
file.separator=/
java.vendor.url.bug=http://developer.apple.com/java/
sun.io.unicode.encoding=UnicodeBig
sun.cpu.endian=big
mrj.version=1040.1.5.0_05-64
proxyPassword=
sun.awt.exception.handler=apple.awt.CToolkit$EventQueueExceptionHandler
sun.cpu.isalist=
