May I know when was the application crashed? Was it crashed when showing the splash screen?
Besides, could you send me the vp.log file inside the bin folder of VP Suite, also the VM log file that is put also in the bin folder?
Jick[/quote]
Hi, thanks for answering. There is no VM log; the vp.log contains
[Fri Mar 16 19:40:58 CET 2007] [message] [Fri Mar 16 19:40:58 CET 2007]: Start Visual Paradigm for UML Community Edition [VP-UML CE]: 6.0 (sp1_20070310)
[Fri Mar 16 19:41:08 CET 2007] [message] [Fri Mar 16 19:41:08 CET 2007]: Start Visual Paradigm for UML Community Edition [VP-UML CE]: 6.0 (sp1_20070310)
[Fri Mar 16 19:41:14 CET 2007] [message] Exception in thread “AWT-EventQueue-0”
[Fri Mar 16 19:41:14 CET 2007] [message] java.lang.NullPointerException
[Fri Mar 16 19:41:14 CET 2007] [message] at javax.swing.plaf.basic.BasicTreeUI.updateExpandedDescendants(BasicTreeUI.java:1558)
[Fri Mar 16 19:41:14 CET 2007] [message] at javax.swing.plaf.basic.BasicTreeUI$Handler.treeExpanded(BasicTreeUI.java:3645)
[Fri Mar 16 19:41:14 CET 2007] [message] at javax.swing.JTree.fireTreeExpanded(JTree.java:2235)
[Fri Mar 16 19:41:14 CET 2007] [message] at javax.swing.JTree.setExpandedState(JTree.java:2956)
[Fri Mar 16 19:41:14 CET 2007] [message] at javax.swing.JTree.expandPath(JTree.java:1742)
[Fri Mar 16 19:41:14 CET 2007] [message] at v.xcs.expandPath(:263)
[Fri Mar 16 19:41:14 CET 2007] [message] at v.xov.run(:1275)
[Fri Mar 16 19:41:14 CET 2007] [message] at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
[Fri Mar 16 19:41:14 CET 2007] [message] at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
[Fri Mar 16 19:41:14 CET 2007] [message] at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
[Fri Mar 16 19:41:14 CET 2007] [message] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
[Fri Mar 16 19:41:14 CET 2007] [message] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
[Fri Mar 16 19:41:14 CET 2007] [message] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
[Fri Mar 16 19:41:14 CET 2007] [message] at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
I’m seeing the splash screen for some seconds before the program crashes.
I would like to send you a special build to try. But I am unable to post here. May I have your email address so that I can discuss with you in further? To avoid spam, you may send me a private message or simply contact me at: jick@visual-paradigm.com
