hello, I have problem to install vp_suite_windows_2.0_2005 community edition.
The install4j wizard is closes before installation is over.
Maybe is finished the install4j wizard but show nothing after wizard.
Intaller isn’t problem because I tried in my desktop PC and was install without any problems.
I had old version of vp for uml, but I can’t install it now, too.
I tried to reinstall my windows XP Pro SP2 and I tested to install vp_suite befor install
any other programs, but a problem was not solved. (same problem)
You may try to move the install vpsuite_xxxx.exe to C:\ and double click to start install. Sometime a complex folder structure (with space or some non-english charcter) may cause problem. If it still not helpe. Please try to use the no-install verion. If there are any further enquiry, please do not hesitate to contact us at http://www.visual-paradigm.com/support/technicalsupport.jsp
Please run the VP Suite.exe in the bin folder after you unzip the no-install zip file. After the VP Suite.exe launched, you will see a user friendly setup program to guide you through the process. If the problem still not solved, I suggest you post a ticket at http://www.visual-paradigm.com/support/technicalsupport.jsp. The techincal team will help you to solve the problem.
