I just downloaded and installed VP UML Community Edition on Solaris 10 x64. The installation had no errors. When executing the run_vpuml script, I get the splash screen and then the application hangs on “Initializing Environment…”
Any ideas?
Any ideas?
Dear John,
Thank you for your email and we are sorry for any inconvenience this problem caused you. Could you mind send me the vp.log file to have a look? You can find the vp.log file inside the bin directory of the VP Suite. You can post the log directly in the forum or send to rain@visual-paradigm.com. Thanks in advance!
Rain
Hi, i have the same problem. I installed VP UML community edition on my linux system. It ran without problems a couple of times, then it just hung up for unknown reason and when i try to start it it just hangs on “Initializing Environment”
My system:
ubuntu linux 5.04, running unter gnome
My vp.log file:
[Mon Aug 15 00:33:32 CEST 2005]: Start Visual Paradigm for UML Community Edition [VP-UML CE]: 5.0 (20050624i)
/usr/share/themes/Clearlooks-DeepSky/gtk-2.0/gtkrc:47:
Engine "clearlooks" is unsupported, ignoring
I also tried to change the current JRE to the one in my own system, without luck:
# Uncomment the following line to override the JVM search sequence
INSTALL4J_JAVA_HOME_OVERRIDE=/usr/lib/j2re1.5-sun/
I appreciate any help!
Thanks in advance!
Could you mind tell me that have you change the Look & Feel of your system?
Rain
Hi Rain, thanks for the reply!
I just changed from the default ubuntu-theme to “clearlooks”. But even in the standard ubuntu theme it does not work anymore.
Now i am in the standard-theme and i uninstalled, giving me this error:
/usr/share/themes/Human/gtk-2.0/gtkrc:7: Failed to parse property value " GTK_SHADOW_NONE " for `GtkMenuItem::shadow-type'
/usr/share/themes/Human/gtk-2.0/gtkrc:58: Engine "clearlooks" is unsupported, ignoring
And when i reinstall i get the same error:
Starting Installer ...
Install works fine, but does not start anyways…
Thanks for your time!
Regards,
Peter
Dear Peter,
Could you please send me your email address so that I can send you some JRE to have a try? You can send me your email address through private message or send to rain@visual-paradigm.com. Thanks in advance!
Rain
Dear John,
I guess your problem could be caused by our bundled JRE is not for x64 systems. I suggest you can replace the JRE directory inside the VP Suite with the 64 bit JRE and try again. If you have any further questions, please feel free to contact us again.
Rain
[quote=John]I just downloaded and installed VP UML Community Edition on Solaris 10 x64. The installation had no errors. When executing the run_vpuml script, I get the splash screen and then the application hangs on “Initializing Environment…”
Any ideas?[/quote]
Dear John,
Could you mind telling me did replacing with a 64 bit JRE can solve your problem? Thanks in advance and I’m looking forward to hear your reply.
Rain
I have the same problem.
I was using VP properly for 10 days.
Then I try to integrate it with JBuilder.
Then it starts to hangs on “Initializing Environment”
I reinstall 2 times, but result was same.
And below, my log file
[Tue Dec 20 16:50:08 EET 2005]: Start Visual Paradigm for UML Enterprise Edition [VP-UML EE]: 5.1 (20051118)
Exception in thread "Thread-2"
at v.jjd.u(:218)
at v.jjd.(:59)
at v.dns.(:81)
at v.luy.i(:134)
at v.luy.i(:55)
at v.qij.D(:336)
at v.qij.l(:215)
at v.vlh.(:593)
at v.lho.f(:180)
at v.lho.i(:29)
at v.pjh.run(:71)
at java.lang.Thread.run(Unknown Source)
[Wed Dec 21 09:54:48 EET 2005]: Start Visual Paradigm for UML Enterprise Edition [VP-UML EE]: 5.1 (20051118)
at v.jjd.u(:218)
at v.jjd.(:59)
at v.dns.(:81)
at v.luy.i(:134)
at v.luy.i(:55)
at v.qij.D(:336)
at v.qij.l(:215)
at v.vlh.(:593)
at v.lho.f(:180)
at v.lho.i(:29)
at v.pjh.run(:71)
[Wed Dec 21 13:53:53 EET 2005]: Start Visual Paradigm for UML Enterprise Edition [VP-UML EE]: 5.1 (20051118)
at v.jjd.u(:218)
at v.jjd.(:59)
at v.dns.(:81)
at v.luy.i(:134)
at v.luy.i(:55)
at v.qij.D(:336)
at v.qij.l(:215)
at v.vlh.(:593)
at v.lho.f(:180)
at v.lho.i(:29)
at v.pjh.run(:71)
[Wed Dec 21 14:09:20 EET 2005]: Start Visual Paradigm for UML Enterprise Edition [VP-UML EE]: 5.1 (20051118)
at v.jjd.u(:218)
at v.jjd.(:59)
at v.dns.(:81)
at v.luy.i(:134)
at v.luy.i(:55)
at v.qij.D(:336)
at v.qij.l(:215)
at v.vlh.(:593)
at v.lho.f(:180)
at v.lho.i(:29)
at v.pjh.run(:71)
[Wed Dec 21 14:14:26 EET 2005]: Start Visual Paradigm for UML Enterprise Edition [VP-UML EE]: 5.1 (20051118)
Thanks for your message. Could you mind tell me the following information of your system?
1.CPU and OS
2.JBuilder version
3.the ignorefonts.txt inside the resources folder of VP Suite
4.any VM error log inside the bin folder of the VP Suite
Thanks in advance!
Rain
[quote=Anonymous]Hello,
at v.jjd.u(:218)
at v.jjd.(:59)
at v.dns.(:81)
at v.luy.i(:134)
at v.luy.i(:55)
at v.qij.D(:336)
at v.qij.l(:215)
at v.vlh.(:593)
at v.lho.f(:180)
at v.lho.i(:29)
at v.pjh.run(:71)
at v.jjd.u(:218)
at v.jjd.(:59)
at v.dns.(:81)
at v.luy.i(:134)
at v.luy.i(:55)
at v.qij.D(:336)
at v.qij.l(:215)
at v.vlh.(:593)
at v.lho.f(:180)
at v.lho.i(:29)
at v.pjh.run(:71)
at v.jjd.u(:218)
at v.jjd.(:59)
at v.dns.(:81)
at v.luy.i(:134)
at v.luy.i(:55)
at v.qij.D(:336)
at v.qij.l(:215)
at v.vlh.(:593)
at v.lho.f(:180)
at v.lho.i(:29)
at v.pjh.run(:71)
at v.jjd.u(:218)
at v.jjd.(:59)
at v.dns.(:81)
at v.luy.i(:134)
at v.luy.i(:55)
at v.qij.D(:336)
at v.qij.l(:215)
at v.vlh.(:593)
at v.lho.f(:180)
at v.lho.i(:29)
at v.pjh.run(:71)
[/quote]
