hi jick,
the configuration is below.
many thanks
-lp
*** Date: Tue May 08 11:00:56 GMT+10:00 2007
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20060629-1905
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
D:\eclipse3.2\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
f74_84
-clean
-vm
C:\WINDOWS\system32\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1178582585421
eclipse.vm=C:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-Xms126m
-Xmx512m
-jar
D:\eclipse3.2\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=D:\eclipse3.2\startup.jar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Java\jre1.5.0_07\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre1.5.0_07\lib\ext
java.home=C:\Program Files\Java\jre1.5.0_07
java.io.tmpdir=C:\DOCUME~1\lucio\LOCALS~1\Temp
java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Microsoft SQL Server\80\Tools\BINN;C:\Program Files\Starbase\StarGate SDK\Lib;d:\kde\bin;C:\Program Files\Vim\vim70;c:\program files\borland\StarTeam SDK 2005 R2\Lib;c:\program files\borland\StarTeam SDK 2005 R2\Bin;D:\CVSNT;;C:\PROGRA~1\COMMON~1\MUVEET~1\030625;C:\PROGRA~1\COMMON~1\MUVEET~1\030625
java.runtime.name=Java™ 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_07-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor=Sun Microsystems Inc.
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_07
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot™ Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_07-b03
jnw.lic.type=Runtime
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax.activity,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start, org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=D:\eclipse3.2\configuration\org.eclipse.osgi\bundles
osgi.clean=true
osgi.configuration.area=file:/D:/eclipse3.2/configuration/
osgi.framework=file:/d:/eclipse3.2/plugins/org.eclipse.osgi_3.2.0.v20060601.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.0.v20060601
osgi.install.area=file:/D:/eclipse3.2/
osgi.instance.area=file:/D:/workspace/poker/
osgi.instance.area.default=file:/C:/Documents and Settings/lucio/workspace/
osgi.logfile=D:\workspace\poker.metadata.log
osgi.manifest.cache=D:\eclipse3.2\configuration\org.eclipse.osgi\manifests
osgi.nl=en_AU
osgi.os=win32
osgi.splashLocation=d:\eclipse3.2\plugins\org.eclipse.platform_3.2.0.v20060601\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=d:\eclipse3.2\plugins
osgi.ws=win32
path.separator=;
proxySet=false
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files\Java\jre1.5.0_07\lib\rt.jar;C:\Program Files\Java\jre1.5.0_07\lib\i18n.jar;C:\Program Files\Java\jre1.5.0_07\lib\sunrsasign.jar;C:\Program Files\Java\jre1.5.0_07\lib\jsse.jar;C:\Program Files\Java\jre1.5.0_07\lib\jce.jar;C:\Program Files\Java\jre1.5.0_07\lib\charsets.jar;C:\Program Files\Java\jre1.5.0_07\classes
sun.boot.library.path=C:\Program Files\Java\jre1.5.0_07\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=AU
user.dir=D:\eclipse3.2
user.home=C:\Documents and Settings\lucio
user.language=en
user.name=lucio
user.timezone=GMT+10:00
user.variant=
*** Features:
org.eclipse.jdt (3.2.0.v20060609m-F7snq1fxia-Z4XP) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.2.0.v20060609m-F7snq1fxia-Z4XP) "Eclipse Java Development Tools SDK"
org.eclipse.pde (3.2.0.v20060609m------6zXJJzJzJq) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.2.0.v20060609m------6zXJJzJzJq) "Eclipse Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.2.0.v20060609m-AgOexn6hlEUsvBO) "Eclipse Platform"
org.eclipse.platform.source (3.2.0.v20060609m-AgOexn6hlEUsvBO) "Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.0.v20060609m-SVDNgVrNoh-MeGG) "Eclipse RCP"
org.eclipse.rcp.source (3.2.0.v20060609m-SVDNgVrNoh-MeGG) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.2.0.v20060609m-GNq6oQq-7es-Y81) “Eclipse Project SDK”
*** Plug-in Registry:
com.atlassw.tools.eclipse.checkstyle (4.0.0) “Checkstyle Plug-in” [Active]
com.hudson.velocityweb (1.0.7) “Velocity Web Edit” [Resolved]
com.ibm.icu (3.4.4.1) “International Components for Unicode for Java (ICU4J)” [Active]
com.ibm.icu.source (3.4.4.1) “International Components for Unicode for Java (ICU4J) source plug-in” [Resolved]
com.icl.saxon (6.5.1) “Saxon-Java XSLT processor” [Resolved]
com.jcraft.jsch (0.1.28) “JSch” [Resolved]
com.quantum.dbunit (3.0.1) “QuantumDB DbUnit Plug-in” [Resolved]
com.quantum.flatfiles (3.0.1) “QuantumDB Data Export-Import Plug-in” [Resolved]
com.quantum.help (3.0.1) “Help Plug-in” [Resolved]
com.quantum.Quantum (3.0.1) “Quantum DB Utility” [Resolved]
com.vp.vpsde.ec (1.0.1) “Smart Development Environment for Eclipse” [Active]
de.byteaction.velocity.ui (2.0.2) “Veloeclipse” [Resolved]
net.sf.elbe (0.5.3) “LDAP Browser and Editor” [Resolved]
net.sf.elbe.core (0.5.3) “LDAP Browser and Editor Core” [Resolved]
net.sf.elbe.help (0.5.3) “LDAP Browser and Editor Help” [Resolved]
net.sf.elbe.ui (0.5.3) “LDAP Browser and Editor UI” [Resolved]
org.apache.ant (1.6.5) “Apache Ant” [Resolved]
org.apache.batik (1.6.0.v20060613-1220) “Apache Batik” [Resolved]
org.apache.batik (1.5.5) “Batik SVG Toolkit” [Installed]
org.apache.batik.pdf (1.6.0.v20060613-1220) “Apache Batik Pdf” [Resolved]
org.apache.commons_logging (1.0.4.v200606131651) “Apache commons logging Plug-in” [Resolved]
org.apache.jakarta_log4j (1.2.8.v200606131651) “Apache Jakarta log4j Plug-in” [Resolved]
org.apache.lucene (1.4.103.v20060601) “Apache Lucene” [Resolved]
org.apache.xerces (2.8.0.v200606131651) “Xerces 2.8.0” [Resolved]
org.drools.ide (3.0.6) “Drools IDE Plug-in” [Active]
org.eclipse.ant.core (3.1.100.v20060531) “Ant Build Tool Core” [Resolved]
org.eclipse.ant.ui (3.2.0.v20060531) “Ant UI” [Resolved]
org.eclipse.compare (3.2.0.v20060605) “Compare Support” [Active]
org.eclipse.core.boot (3.1.100.v20060603) “Core Boot” [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) “Commands” [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) “Eclipse Content Mechanism” [Active]
org.eclipse.core.expressions (3.2.0.v20060605-1400) “Expression Language” [Active]
org.eclipse.core.filebuffers (3.2.0.v20060605-1400) “File Buffers” [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) “Core File Systems” [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) “Core File System for Windows” [Resolved]
org.eclipse.core.jobs (3.2.0.v20060603) “Eclipse Jobs Mechanism” [Active]
org.eclipse.core.resources (3.2.0.v20060603) “Core Resource Management” [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) “Core Resource Management Compatibility Fragment” [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060603) “Core Resource Management Win32 Fragment” [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) “Core Runtime” [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) “Core Runtime Plug-in Compatibility” [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601) “Authorization Compatibility Plug-in” [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.0.v20060603) “Eclipse Registry Compatibility Fragment” [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) “Core Variables” [Resolved]
org.eclipse.debug.core (3.2.0.v20060605) “Debug Core” [Active]
org.eclipse.debug.ui (3.2.0.v20060605) “Debug UI” [Active]
org.eclipse.draw2d (3.2.1.v20060921) “Draw2d” [Resolved]
org.eclipse.draw2d (3.2.0.v20060626) “Draw2d” [Resolved]
org.eclipse.emf (2.2.0.v200609210005) “Eclipse Modeling Framework (EMF)” [Resolved]
org.eclipse.emf (2.2.0.v200609071016) “Eclipse Modeling Framework (EMF)” [Resolved]
org.eclipse.emf.ant (2.2.0.v200609210005) “EMF Ant Tasks” [Resolved]
org.eclipse.emf.ant (2.2.0.v200609071016) “EMF Ant Tasks” [Installed]
org.eclipse.emf.cheatsheets (2.2.0.v200609210005) “EMF Cheat Sheets” [Resolved]
org.eclipse.emf.cheatsheets (2.2.0.v200609071016) “EMF Cheat Sheets” [Installed]
org.eclipse.emf.codegen (2.2.1.v200609210005) “EMF Template Code Generator” [Resolved]
org.eclipse.emf.codegen (2.2.1.v200609071016) “EMF Template Code Generator” [Installed]
org.eclipse.emf.codegen.ecore (2.2.1.v200609210005) “EMF Ecore Code Generation” [Resolved]
org.eclipse.emf.codegen.ecore (2.2.1.v200609071016) “EMF Ecore Code Generation” [Installed]
org.eclipse.emf.codegen.ecore.ui (2.2.1.v200609210005) “EMF Ecore Code Generation UI” [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.1.v200609071016) “EMF Ecore Code Generation UI” [Installed]
org.eclipse.emf.codegen.ui (2.1.0.v200609210005) “EMF Template Code Generator UI” [Resolved]
org.eclipse.emf.codegen.ui (2.1.0.v200609071016) “EMF Template Code Generator UI” [Installed]
org.eclipse.emf.common (2.2.1.v200609210005) “EMF Common” [Active]
org.eclipse.emf.common (2.2.1.v200609071016) “EMF Common” [Resolved]
org.eclipse.emf.common.ui (2.2.1.v200609210005) “EMF Common UI” [Resolved]
org.eclipse.emf.common.ui (2.2.1.v200609071016) “EMF Common UI” [Installed]
org.eclipse.emf.commonj.sdo (2.1.0.v200609210005) “CommonJ SDO” [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0.v200609071016) “CommonJ SDO” [Resolved]
org.eclipse.emf.converter (2.2.1.v200609210005) “EMF Model Convert Support” [Resolved]
org.eclipse.emf.converter (2.2.1.v200609071016) “EMF Model Convert Support” [Installed]
org.eclipse.emf.doc (2.2.1.v200609210005) “Eclipse Modeling Framework (EMF) Programmers Guide” [Resolved]
org.eclipse.emf.ecore (2.2.1.v200609210005) “EMF Ecore” [Active]
org.eclipse.emf.ecore (2.2.1.v200609071016) “EMF Ecore” [Installed]
org.eclipse.emf.ecore.change (2.2.0.v200609210005) “EMF Ecore Change Model” [Resolved]
org.eclipse.emf.ecore.change (2.2.0.v200609071016) “EMF Ecore Change Model” [Installed]
org.eclipse.emf.ecore.change.edit (2.2.0.v200609210005) “EMF Ecore Change Edit Support” [Resolved]
org.eclipse.emf.ecore.change.edit (2.2.0.v200609071016) “EMF Ecore Change Edit Support” [Installed]
org.eclipse.emf.ecore.edit (2.2.0.v200609210005) “EMF Ecore Edit Support” [Resolved]
org.eclipse.emf.ecore.edit (2.2.0.v200609071016) “EMF Ecore Edit Support” [Installed]
org.eclipse.emf.ecore.editor (2.2.0.v200609210005) “Sample Ecore Editor” [Resolved]
org.eclipse.emf.ecore.editor (2.2.0.v200609071016) “Sample Ecore Editor” [Installed]
org.eclipse.emf.ecore.sdo (2.2.0.v200609210005) “EMF Service Data Objects (SDO)” [Resolved]
org.eclipse.emf.ecore.sdo (2.2.0.v200609071016) “EMF Service Data Objects (SDO)” [Installed]
org.eclipse.emf.ecore.sdo.doc (2.2.1.v200609210005) “EMF Service Data Objects (SDO) Programmers Guide” [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.2.0.v200609210005) “EMF Service Data Objects (SDO) Edit Support” [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.2.0.v200609071016) “EMF Service Data Objects (SDO) Edit Support” [Installed]
org.eclipse.emf.ecore.sdo.editor (2.2.0.v200609210005) “EMF Service Data Objects (SDO) Editor” [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.2.0.v200609071016) “EMF Service Data Objects (SDO) Editor” [Installed]
org.eclipse.emf.ecore.sdo.source (2.2.0.v200609210005) “EMF Service Data Objects (SDO) Source” [Resolved]
org.eclipse.emf.ecore.xmi (2.2.1.v200609210005) “EMF XMI” [Active]
org.eclipse.emf.ecore.xmi (2.2.1.v200609071016) “EMF XMI” [Installed]
org.eclipse.emf.edit (2.2.1.v200609210005) “EMF Edit” [Resolved]
org.eclipse.emf.edit (2.2.1.v200609071016) “EMF Edit” [Installed]
org.eclipse.emf.edit.ui (2.2.0.v200609210005) “EMF Edit UI” [Resolved]
org.eclipse.emf.edit.ui (2.2.0.v200609071016) “EMF Edit UI” [Resolved]
org.eclipse.emf.exporter (2.2.0.v200609210005) “EMF Model Export Support” [Resolved]
org.eclipse.emf.exporter (2.2.0.v200609071016) “EMF Model Export Support” [Installed]
org.eclipse.emf.importer (2.2.1.v200609210005) “EMF Model Import Support” [Resolved]
org.eclipse.emf.importer (2.2.1.v200609071016) “EMF Model Import Support” [Installed]
org.eclipse.emf.importer.ecore (2.2.0.v200609210005) “EMF Ecore Importer” [Resolved]
org.eclipse.emf.importer.ecore (2.2.0.v200609071016) “EMF Ecore Importer” [Installed]
org.eclipse.emf.importer.java (2.2.1.v200609210005) “EMF Annotated Java Importer” [Resolved]
org.eclipse.emf.importer.java (2.2.1.v200609071016) “EMF Annotated Java Importer” [Installed]
org.eclipse.emf.importer.rose (2.2.0.v200609210005) “EMF Rose Importer” [Resolved]
org.eclipse.emf.importer.rose (2.2.0.v200609071016) “EMF Rose Importer” [Installed]
org.eclipse.emf.mapping (2.2.0.v200609210005) “EMF Mapping” [Resolved]
org.eclipse.emf.mapping (2.2.0.v200609071016) “EMF Mapping” [Installed]
org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200609210005) “Ecore to Ecore Mapping” [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200609071016) “Ecore to Ecore Mapping” [Installed]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200609210005) “Ecore to Ecore Mapping Editor” [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200609071016) “Ecore to Ecore Mapping Editor” [Installed]
org.eclipse.emf.mapping.ecore2xml (2.2.0.v200609210005) “Ecore to XML Mapping” [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0.v200609071016) “Ecore to XML Mapping” [Installed]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0.v200609210005) “Ecore to XML Mapping UI” [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0.v200609071016) “Ecore to XML Mapping UI” [Installed]
org.eclipse.emf.mapping.ui (2.2.1.v200609210005) “EMF Mapping UI” [Resolved]
org.eclipse.emf.mapping.ui (2.2.1.v200609071016) “EMF Mapping UI” [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0.v200609210005) “XSD to Ecore Mapping” [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0.v200609071016) “XSD to Ecore Mapping” [Installed]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0.v200609210005) “XSD to Ecore Mapping Editor” [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0.v200609071016) “XSD to Ecore Mapping Editor” [Installed]
org.eclipse.emf.source (2.2.1.v200609210005) “Eclipse Modeling Framework (EMF) Source” [Resolved]
org.eclipse.equinox.common (3.2.0.v20060603) “Common Eclipse Runtime” [Active]
org.eclipse.equinox.preferences (3.2.0.v20060601) “Eclipse Preferences Mechanism” [Active]
org.eclipse.equinox.registry (3.2.0.v20060601) “Extension Registry Support” [Active]
org.eclipse.gef (3.2.1.v20060921) “Graphical Editing Framework” [Resolved]
org.eclipse.gef (3.2.0.v20060626) “Graphical Editing Framework” [Installed]
org.eclipse.help (3.2.0.v20060602) “Help System Core” [Active]
org.eclipse.help.appserver (3.1.100.v20060602) “Help Application Server” [Resolved]
org.eclipse.help.base (3.2.0.v20060601) “Help System Base” [Resolved]
org.eclipse.help.ui (3.2.0.v20060602) “Help System UI” [Resolved]
org.eclipse.help.webapp (3.2.0.v20060602) “Help System Webapp” [Resolved]
org.eclipse.hyades.analysis.engine (4.2.0.v200606131519) “Symptom Model” [Resolved]
org.eclipse.hyades.execution (4.2.0.v200606131519) “TPTP Platform Execution Plug-In” [Active]
org.eclipse.hyades.execution.correlation (4.1.100.v200606131519) “Hyades Runtime Correlation Engine” [Resolved]
org.eclipse.hyades.execution.trace (4.1.100.v200606131519) “Hyades Execution Trace” [Resolved]
org.eclipse.hyades.execution.win32.x86 (4.2.0.v200606131519) “TPTP Platform Execution Plug-In” [Resolved]
org.eclipse.hyades.logging.adapter (4.2.0.v200606170100) “TPTP Monitoring Project Generic Log Adapter” [Resolved]
org.eclipse.hyades.logging.adapter.ui (4.2.0.v200606131519) “Generic Adapter UI” [Resolved]
org.eclipse.hyades.logging.core (4.2.0.v200606131519) “Hyades Logging Agent, Common Base Events and Logging Facility Support” [Resolved]
org.eclipse.hyades.logging.core.sample (4.1.100.v200606131519) “Sample for Hyades Logging Agent, Common Base Events and Logging Facility Support” [Resolved]
org.eclipse.hyades.logging.parsers (4.2.0.v200606190100) “TPTP Monitoring Project Log File Parsers” [Resolved]
org.eclipse.hyades.perfmon (4.2.0.v200606131519) “Perfmon StatCon Module” [Resolved]
org.eclipse.hyades.probekit (4.2.0.v200606131519) “Hyades Probekit” [Resolved]
org.eclipse.hyades.probekit.doc.user (4.1.100.v200606131519) “Probekit User Documentation” [Resolved]
org.eclipse.hyades.probekit.ui (4.1.100.v200606131519) “Probe Editor” [Resolved]
org.eclipse.hyades.resources.database (4.1.100.v200606190100) “Hyades Core Resource Extensions” [Resolved]
org.eclipse.hyades.sdb (4.1.100.v200606140100) “Symptom Database tool” [Resolved]
org.eclipse.hyades.statistical.ui (4.2.0.v200606131519) “Statistical UI” [Active]
org.eclipse.hyades.test.core (4.2.0.v200606131519) “TPTP Test Core Plug-In” [Resolved]
org.eclipse.hyades.test.doc.user (4.1.100.v200606131519) “Test Tools User Documentation” [Resolved]
org.eclipse.hyades.test.tools.core (4.2.0.v200606131519) “TPTP Test Tools Core Plug-In” [Resolved]
org.eclipse.hyades.test.tools.ui (4.2.0.v200606131519) “TPTP Test Tools UI Plug-In” [Resolved]
org.eclipse.hyades.test.ui (4.2.0.v200606131519) “TPTP Test UI Plug-In” [Resolved]
org.eclipse.hyades.test.ui.extensions (4.2.0.v200606131519) “TPTP Test UI Extension Plug-In” [Resolved]
org.eclipse.hyades.trace.sample (4.1.100.v200606131519) “Samples for the TPTP Monitoring Tools Plugins” [Resolved]
org.eclipse.hyades.trace.ui (4.2.0.v200606131519) “Hyades Trace Core UI” [Active]
org.eclipse.hyades.trace.views (4.1.100.v200606131519) “Hyades Trace Views Plugin” [Resolved]
org.eclipse.hyades.ui (4.1.100.v200606131519) “Hyades UI” [Active]
org.eclipse.jdt (3.2.0.v20060605-1400) “Eclipse Java Development Tools” [Resolved]
org.eclipse.jdt.apt.core (3.2.0.v20060602-1740) “Java Annotation Processing Core” [Active]
org.eclipse.jdt.apt.ui (3.2.0.v20060602-1740) “Java Annotation Processing UI” [Resolved]
org.eclipse.jdt.core (3.2.0.v_671) “Java Development Tools Core” [Active]
org.eclipse.jdt.core.manipulation (1.0.0.v20060605-1400) “Java Code Manipulation Functionality” [Resolved]
org.eclipse.jdt.debug (3.2.0.v20060605) “JDI Debug Model” [Active]
org.eclipse.jdt.debug.ui (3.2.0.v20060605) “JDI Debug UI” [Active]
org.eclipse.jdt.doc.isv (3.2.0.v20060605-1400) “Eclipse JDT Plug-in Developer Guide” [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060605-1400) “Eclipse Java Development User Guide” [Resolved]
org.eclipse.jdt.junit (3.2.0.v20060605-1400) “Java Development Tools JUnit support” [Active]
org.eclipse.jdt.junit.runtime (3.2.0.v20060605-1400) “Java Development Tools JUnit runtime support” [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.0.v20060605-1400) “Java Development Tools JUnit4 runtime support” [Resolved]
org.eclipse.jdt.launching (3.2.0.v20060605) “Java Development Tools Launching Support” [Active]
org.eclipse.jdt.source (3.2.0.v20060609m-F7snq1fxia-Z4XP) “Eclipse Java Development Tools SDK” [Resolved]
org.eclipse.jdt.ui (3.2.0.v20060605-1400) “Java Development Tools UI” [Active]
org.eclipse.jface (3.2.0.I20060605-1400) “JFace” [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) “JFace Data Binding” [Resolved]
org.eclipse.jface.text (3.2.0.v20060605-1400) “JFace Text” [Resolved]
org.eclipse.ltk.core.refactoring (3.2.0.v20060605-1400) “Refactoring Core” [Active]
org.eclipse.ltk.ui.refactoring (3.2.0.v20060605-1400) “Refactoring UI” [Active]
org.eclipse.osgi.services (3.1.100.v20060601) “OSGi Release 3 Services” [Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) “OSGi R3 Utility Classes” [Resolved]
org.eclipse.pde (3.2.0.v20060605) “Eclipse Plug-in Development Environment” [Resolved]
org.eclipse.pde.build (3.2.0.v20060603) “Plug-in Development Environment Build Support” [Resolved]
org.eclipse.pde.core (3.2.0.v20060605) “Plug-in Development Core” [Resolved]
org.eclipse.pde.doc.user (3.2.0.v20060605) “Eclipse Plug-in Development User Guide” [Resolved]
org.eclipse.pde.junit.runtime (3.2.0.v20060605) “PDE JUnit Plug-in Test” [Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) “Plug-in Development Environment Runtime” [Resolved]
org.eclipse.pde.source (3.2.0.v20060609m------6zXJJzJzJq) “Eclipse Plug-in Development Environment Developer Resources” [Resolved]
org.eclipse.pde.ui (3.2.0.v20060605) “Plug-in Development UI” [Resolved]
org.eclipse.platform (3.2.0.v20060601) “Eclipse Platform” [Active]
org.eclipse.platform.doc.isv (3.2.0.v20060612-0900) “Eclipse Platform Plug-in Developer Guide” [Resolved]
org.eclipse.platform.doc.user (3.2.0.v20060605) “Eclipse Workbench User Guide” [Resolved]
org.eclipse.platform.source (3.2.0.v20060609m-AgOexn6hlEUsvBO) “Eclipse Platform Plug-in Developer Resources” [Resolved]
org.eclipse.platform.source.win32.win32.x86 (3.2.0.v20060609m-AgOexn6hlEUsvBO) “Eclipse Platform Plug-in Developer Resources” [Resolved]
org.eclipse.rcp (3.2.0.v20060605) “Eclipse RCP” [Resolved]
org.eclipse.rcp.source (3.2.0.v20060609m-SVDNgVrNoh-MeGG) “Eclipse RCP Plug-in Developer Resources” [Resolved]
org.eclipse.rcp.source.win32.win32.x86 (3.2.0.v20060609m-SVDNgVrNoh-MeGG) “Eclipse RCP Plug-in Developer Resources” [Resolved]
org.eclipse.sdk (3.2.0.v20060605) “Eclipse Project SDK” [Resolved]
org.eclipse.search (3.2.0.v20060605-1400) “Search Support” [Resolved]
org.eclipse.swt (3.2.0.v3232o) “Standard Widget Toolkit” [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.0.v3232m) “Standard Widget Toolkit for Windows” [Resolved]
org.eclipse.team.core (3.2.0.I200606051140) “Team Support Core” [Active]
org.eclipse.team.cvs.core (3.2.0.M20060628) “CVS Team Provider Core” [Resolved]
org.eclipse.team.cvs.ssh (3.2.0.I200606011710) “CVS SSH Core” [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.0.I200606051140) “CVS SSH2” [Resolved]
org.eclipse.team.cvs.ui (3.2.0.I200606051140) “CVS Team Provider UI” [Resolved]
org.eclipse.team.ui (3.2.0.I200606051140) “Team Support UI” [Active]
org.eclipse.text (3.2.0.v20060605-1400) “Text” [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) “Tomcat Wrapper” [Resolved]
org.eclipse.tptp.monitoring (4.1.100.v200606131519) “TPTP Monitoring” [Resolved]
org.eclipse.tptp.monitoring.doc.user (4.2.0.v200606131519) “TPTP Monitoring Project Documentation” [Resolved]
org.eclipse.tptp.monitoring.examples (4.2.0.v200606131519) “User examples for the TPTP Monitoring Tools Plugins” [Resolved]
org.eclipse.tptp.monitoring.logui (4.2.0.v200606131519) “Logui Plug-in” [Resolved]
org.eclipse.tptp.monitoring.profile.server (4.1.100.v200606131519) “TPTP Profile On Server Logging Utility” [Resolved]
org.eclipse.tptp.monitoring.report.birt (4.2.0.v200606131519) “BIRT Monitor Reports for TPTP Branding Plugin” [Resolved]
org.eclipse.tptp.monitoring.report.birt.doc.user (4.2.0.v200606131519) “Monitoring Tools Business Intelligence Reporting Tools Doc User Plug-in” [Resolved]
org.eclipse.tptp.monitoring.report.birt.ui (4.2.0.v200606131519) “BIRT Monitor Reports for TPTP” [Resolved]
org.eclipse.tptp.platform.agentcontroller (4.1.100.v200606170100) “TPTP Agent Controller” [Resolved]
org.eclipse.tptp.platform.agentcontroller.doc.user (4.2.0.v200606131519) “Agent Controller documentation” [Resolved]
org.eclipse.tptp.platform.analysis (4.1.100.v200606131519) “TPTP Analysis” [Resolved]
org.eclipse.tptp.platform.analysis.codereview.java (4.2.0.v200606131519) “Java Code Review Plug-in” [Resolved]
org.eclipse.tptp.platform.analysis.codereview.java.rules (4.2.0.v200606131519) “Java Code Review Rules Plug-in” [Resolved]
org.eclipse.tptp.platform.analysis.core (4.2.0.v200606131519) “TPTP Analysis Framework Core Plug-in” [Resolved]
org.eclipse.tptp.platform.analysis.core.ui (4.2.0.v200606131519) “Static Analysis User Interface Plug-in” [Active]
org.eclipse.tptp.platform.analysis.core.ui.doc (4.2.0.v200606131519) “Analysis run cofiguration online help” [Resolved]
org.eclipse.tptp.platform.analysis.engine (4.1.100.v200606131519) “TPTP Analysis Engine” [Resolved]
org.eclipse.tptp.platform.collection.framework (4.1.100.v200606131519) “TPTP Collection Framework” [Resolved]
org.eclipse.tptp.platform.core (4.1.100.v200606131519) “TPTP Platform” [Resolved]
org.eclipse.tptp.platform.doc.user (4.1.100.v200606131519) “TPTP Platform Project Documentation” [Resolved]
org.eclipse.tptp.platform.examples (4.2.0.v200606131519) “TPTP Platform Examples” [Resolved]
org.eclipse.tptp.platform.execution (4.2.0.v200606140100) “TPTP Core Platform (Provisional)” [Resolved]
org.eclipse.tptp.platform.log.views (4.2.0.v200606131519) “Hyades Log UI” [Resolved]
org.eclipse.tptp.platform.lta (4.1.100.v200606131519) “TPTP Log and Trace Analyzer” [Resolved]
org.eclipse.tptp.platform.models (4.2.0.v200606131519) “Hyades Models” [Active]
org.eclipse.tptp.platform.probekit (4.1.100.v200606131519) “TPTP ProbeKit” [Resolved]
org.eclipse.tptp.platform.probekit.launch (4.2.0.v200606131519) “Probekit Launch Configuration” [Resolved]
org.eclipse.tptp.platform.profile.server (4.1.100.v200606131519) “TPTP Profile on Server” [Resolved]
org.eclipse.tptp.platform.profile.server.core (4.1.100.v200606131519) “TPTP Profile On Server Core” [Resolved]
org.eclipse.tptp.platform.profile.server.wst (4.1.100.v200606131519) “TPTP Profile On Server WTP Utility” [Resolved]
org.eclipse.tptp.platform.report (4.1.100.v200606131519) “TPTP Charting Service” [Resolved]
org.eclipse.tptp.platform.report.birt (4.2.0.v200606131519) “BIRT Reporting for TPTP Branding plugin” [Resolved]
org.eclipse.tptp.platform.report.birt.ui (4.2.0.v200606131519) “BIRT Reporting for TPTP” [Resolved]
org.eclipse.tptp.platform.report.core (4.1.100.v200606131519) “TPTP Report Framework” [Resolved]
org.eclipse.tptp.platform.report.ui (4.1.100.v200606131519) “TPTP Report UI” [Resolved]
org.eclipse.tptp.platform.samples (4.1.100.v200606131519) “TPTP Platform Samples” [Resolved]
org.eclipse.tptp.platform.statistical.ui (4.1.100.v200606131519) “TPTP Statistical UI” [Resolved]
org.eclipse.tptp.platform.trace (4.1.100.v200606131519) “TPTP Platform Trace” [Resolved]
org.eclipse.tptp.test (4.1.100.v200606131519) “TPTP Test” [Resolved]
org.eclipse.tptp.test.report.birt (4.2.0.v200606131519) “BIRT Test Reports for TPTP Branding Plugin” [Resolved]
org.eclipse.tptp.test.report.birt.doc.user (4.2.0.v200606131519) “Testing Tools Business Intelligence Reporting Tools Doc User Plug-in” [Resolved]
org.eclipse.tptp.test.report.birt.ui (4.2.0.v200606131519) “BIRT Test Reports for TPTP” [Resolved]
org.eclipse.tptp.test.samples (4.1.100.v200606131519) “TPTP Test Samples” [Resolved]
org.eclipse.tptp.test.tools (4.1.100.v200606131519) “TPTP Test Tools” [Resolved]
org.eclipse.tptp.trace (4.1.100.v200606131519) “TPTP Trace” [Resolved]
org.eclipse.tptp.trace.report.birt (4.2.0.v200606131519) “BIRT Trace Reports for TPTP Branding Plugin” [Resolved]
org.eclipse.tptp.trace.report.birt.doc.user (4.2.0.v200606131519) “Tracing and Profiling Tools Business Intelligence Reporting Tools Doc User Plug-in” [Resolved]
org.eclipse.tptp.trace.report.birt.ui (4.2.0.v200606131519) “BIRT Trace Reports for TPTP” [Resolved]
org.eclipse.ui (3.2.0.I20060605-1400) “Eclipse UI” [Active]
org.eclipse.ui.browser (3.2.0.v20060602) “Browser Support” [Resolved]
org.eclipse.ui.cheatsheets (3.2.0.v20060602) “Cheat Sheets” [Resolved]
org.eclipse.ui.console (3.1.100.v20060605) “Console” [Resolved]
org.eclipse.ui.editors (3.2.0.v20060605-1400) “Default Text Editor” [Active]
org.eclipse.ui.externaltools (3.1.100.v20060605) “External Tools” [Active]
org.eclipse.ui.forms (3.2.0.v20060602) “Eclipse Forms” [Resolved]
org.eclipse.ui.ide (3.2.0.I20060605-1400) “Eclipse IDE UI” [Active]
org.eclipse.ui.intro (3.2.0.v20060601) “Welcome Framework” [Resolved]
org.eclipse.ui.intro.universal (3.2.0.v20060602) “Universal Welcome” [Resolved]
org.eclipse.ui.navigator (3.2.0.I20060605-1400) “Common Navigator View” [Resolved]
org.eclipse.ui.navigator.resources (3.2.0.I20060605-1400) “Navigator Workbench Components” [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) “R21 Presentation Plug-in” [Resolved]
org.eclipse.ui.views (3.2.0.I20060605-1400) “Views” [Active]
org.eclipse.ui.views.properties.tabbed (3.2.0.I20060605-1400) “Tabbed Properties View” [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060605-1400) “Eclipse UI Win32 Enhancements” [Resolved]
org.eclipse.ui.workbench (3.2.0.I20060605-1400) “Workbench” [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) “Workbench Compatibility” [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060605-1400) “Text Editor Framework” [Active]
org.eclipse.uml2 (2.0.1.v200609071509) “UML2” [Resolved]
org.eclipse.uml2 (2.0.1.v200609210850) “UML2” [Resolved]
org.eclipse.uml2.codegen.ecore (1.2.1.v200609071509) “UML2 Ecore Code Generation” [Installed]
org.eclipse.uml2.codegen.ecore (1.2.1.v200609210850) “UML2 Ecore Code Generation” [Resolved]
org.eclipse.uml2.codegen.ecore.ui (1.2.0.v200609071509) “UML2 Ecore Code Generation UI” [Installed]
org.eclipse.uml2.codegen.ecore.ui (1.2.0.v200609210850) “UML2 Ecore Code Generation UI” [Resolved]
org.eclipse.uml2.common (1.2.1.v200609071509) “UML2 Common” [Resolved]
org.eclipse.uml2.common (1.2.1.v200609210850) “UML2 Common” [Resolved]
org.eclipse.uml2.common.edit (1.2.0.v200609071509) “UML2 Common Edit Support” [Resolved]
org.eclipse.uml2.common.edit (1.2.0.v200609210850) “UML2 Common Edit Support” [Resolved]
org.eclipse.uml2.examples (2.0.1.v200609071509) “UML2 Examples” [Resolved]
org.eclipse.uml2.examples (2.0.1.v200609210850) “UML2 Examples” [Resolved]
org.eclipse.uml2.examples.uml.ui (2.0.1.v200609071509) “UML2 UML Examples UI” [Installed]
org.eclipse.uml2.examples.uml.ui (2.0.1.v200609210850) “UML2 UML Examples UI” [Resolved]
org.eclipse.uml2.uml (2.0.1.v200609071509) “UML2 UML Model” [Installed]
org.eclipse.uml2.uml (2.0.1.v200609210850) “UML2 UML Model” [Resolved]
org.eclipse.uml2.uml.ecore.exporter (2.0.0.v200609071509) “UML2 UML Exporter for EMF” [Installed]
org.eclipse.uml2.uml.ecore.exporter (2.0.0.v200609210850) “UML2 UML Exporter for EMF” [Resolved]
org.eclipse.uml2.uml.ecore.importer (2.0.0.v200609071509) “UML2 UML Importer for EMF” [Installed]
org.eclipse.uml2.uml.ecore.importer (2.0.0.v200609210850) “UML2 UML Importer for EMF” [Resolved]
org.eclipse.uml2.uml.edit (2.0.0.v200609071509) “UML2 UML Edit Support” [Installed]
org.eclipse.uml2.uml.edit (2.0.1.v200609210850) “UML2 UML Edit Support” [Resolved]
org.eclipse.uml2.uml.editor (2.0.1.v200609071509) “UML2 UML Editor” [Installed]
org.eclipse.uml2.uml.editor (2.0.1.v200609210850) “UML2 UML Editor” [Resolved]
org.eclipse.uml2.uml.resources (2.0.1.v200609071509) “UML2 UML Resources” [Installed]
org.eclipse.uml2.uml.resources (2.0.1.v200609210850) “UML2 UML Resources” [Resolved]
org.eclipse.update.configurator (3.2.0.v20060605) “Install/Update Configurator” [Active]
org.eclipse.update.core (3.2.0.v20060605) “Install/Update Core” [Active]
org.eclipse.update.core.win32 (3.2.0.v20060605) “Install/Update Core for Windows” [Resolved]
org.eclipse.update.scheduler (3.2.0.v20060605) “Automatic Updates Scheduler” [Active]
org.eclipse.update.ui (3.2.0.v20060605) “Install/Update UI” [Resolved]
org.eclipse.xsd (2.2.1.v200609210005) “XML Schema Infoset Model (XSD)” [Resolved]
org.eclipse.xsd (2.2.1.v200609071016) “XML Schema Infoset Model (XSD)” [Installed]
org.eclipse.xsd.cheatsheets (2.2.0.v200609210005) “XML Schema Infoset Model (XSD) Cheat Sheets” [Resolved]
org.eclipse.xsd.cheatsheets (2.2.0.v200609071016) “XML Schema Infoset Model (XSD) Cheat Sheets” [Installed]
org.eclipse.xsd.doc (2.2.1.v200609210005) “XML Schema Infoset Model (XSD) Programmers Guide” [Resolved]
org.eclipse.xsd.ecore.exporter (2.2.1.v200609210005) “XML Schema Exporter for EMF” [Resolved]
org.eclipse.xsd.ecore.exporter (2.2.1.v200609071016) “XML Schema Exporter for EMF” [Installed]
org.eclipse.xsd.ecore.importer (2.2.0.v200609210005) “XML Schema Importer for EMF” [Resolved]
org.eclipse.xsd.ecore.importer (2.2.0.v200609071016) “XML Schema Importer for EMF” [Installed]
org.eclipse.xsd.edit (2.2.1.v200609210005) “XML Schema Edit Framework” [Resolved]
org.eclipse.xsd.edit (2.2.1.v200609071016) “XML Schema Edit Framework” [Installed]
org.eclipse.xsd.editor (2.2.0.v200609210005) “XML Schema Editor” [Resolved]
org.eclipse.xsd.editor (2.2.0.v200609071016) “XML Schema Editor” [Installed]
org.eclipse.xsd.source (2.2.1.v200609210005) “XML Schema Infoset Model (XSD) Source” [Resolved]
org.junit (3.8.1) “JUnit Testing Framework” [Resolved]
org.junit4 (4.1.0) “JUnit Testing Framework Version 4” [Resolved]
org.python.pydev (1.2.2) “Pydev - Python Development Environment” [Resolved]
org.python.pydev.ast (1.2.2) “Ast Plug-in” [Resolved]
org.python.pydev.core (1.2.2) “Core Plug-in” [Resolved]
org.python.pydev.debug (1.2.2) “Pydev debug” [Resolved]
org.python.pydev.help (1.2.2) “Pydev Online Help” [Resolved]
org.python.pydev.jython (1.2.2) “Jython Plug-in” [Resolved]
org.python.pydev.parser (1.2.2) “Parser Plug-in” [Resolved]
org.python.pydev.templates (1.2.2) “Templates Plug-in” [Resolved]
ru.novosoft.nsuml (1.4) “Novosoft NSUML” [Installed]
system.bundle (3.2.0.v20060601) “OSGi System Bundle” [Active]
*** User Preferences:
#Tue May 08 11:00:57 GMT+10:00 2007
@org.eclipse.debug.ui=3.2.0.v20060605
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION=D:\eclipse3.2\plugins\org.eclipse.hyades.execution_4.2.0.v200606131519\hexl.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.execution_4.2.0.v200606131519\hexr.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.execution_4.2.0.v200606131519\tptp-automation-client.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.execution_4.2.0.v200606131519\tptp-automation-server.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.execution_4.2.0.v200606131519\hexcore.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.execution.win32.x86_4.2.0.v200606131519\.;D:\eclipse3.2\plugins\org.eclipse.hyades.execution.win32.x86_4.2.0.v200606131519\bin;D:\eclipse3.2\plugins\org.eclipse.hyades.execution_4.2.0.v200606131519\bin;
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_templates=<?xml version\="1.0" encoding\="UTF-8"?>
@org.eclipse.ui.ide=3.2.0.I20060605-1400
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.packages.linktoeditor=true
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launching.PREF_VM_XML=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings defaultVM=“57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType13,1173744904781” defaultVMConnector="">\r\n<vmType id=“org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType”>\r\n<vm id=“1173744904781” javadocURL=“http://java.sun.com/j2se/1.5.0/docs/api/” name=“jre1.5.0_07” path=“C:\Program Files\Java\jre1.5.0_07”/>\r\n\r\n\r\n
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_templates_migrated=true
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_HYADES_LOGGING_CORE=D:\eclipse3.2\plugins\org.eclipse.hyades.logging.core_4.2.0.v200606131519
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.internal.ui.PackageExplorer.EmptyInnerPackageFilter=true
/instance/org.eclipse.hyades.ui/filters.filterSelection=\n
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_HYADES_PROBEKIT=D:\eclipse3.2\plugins\org.eclipse.hyades.probekit_4.2.0.v200606131519\probekit.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.probekit_4.2.0.v200606131519\bin;
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.PackageExplorer.SyntheticMembersFilter=true
/instance/org.eclipse.jdt.ui/CustomFiltersActionGroup.org.eclipse.jdt.ui.PackageExplorer.TAG_DUMMY_TO_TEST_EXISTENCE=storedViewPreferences
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_HYADES_PERFMON_AGENTS=;%CUSTOMPATH_ORG_ECLIPSE_HYADES_PERFMON_AGENTS%\core\lib\coreagent.jar
/instance/org.eclipse.ui.editors/overviewRuler_migration=migrated_3.1
@org.eclipse.jdt.ui=3.2.0.v20060605-1400
/instance/org.eclipse.core.resources/version=1
@org.eclipse.hyades.ui=4.1.100.v200606131519
@org.eclipse.core.resources=3.2.0.v20060603
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.help.ui/browser.y=29
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.PackageExplorer.ImportDeclarationFilter=true
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.help.ui/browser.x=22
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_CORE_COMMANDS=D:\eclipse3.2\plugins\org.eclipse.core.commands_3.2.0.I20060605-1400.jar;
/instance/org.eclipse.help.ui/browser.w=1024
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_EMF_COMMON=D:\eclipse3.2\plugins\org.eclipse.emf.common_2.2.1.v200609210005.jar;
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_HYADES_TEST_TOOLS_CORE=D:\eclipse3.2\plugins\org.eclipse.hyades.test.tools.core_4.2.0.v200606131519
file_export_version=3.0
@org.eclipse.jdt.launching=3.2.0.v20060605
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.width=
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_MODELS=D:\eclipse3.2\plugins\org.eclipse.tptp.platform.models_4.2.0.v200606131519\tptp-models.jar;D:\eclipse3.2\plugins\org.eclipse.tptp.platform.models_4.2.0.v200606131519\fastxpath.jar;D:\eclipse3.2\plugins\org.eclipse.tptp.platform.models_4.2.0.v200606131519\fastxpath-sun50.jar;D:\eclipse3.2\plugins\org.eclipse.tptp.platform.models_4.2.0.v200606131519\bin;
/instance/org.eclipse.help.ui/browser.h=768
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Courier New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_TPTP_PLATFORM_MODELS=D:\eclipse3.2\plugins\org.eclipse.tptp.platform.models_4.2.0.v200606131519
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.enumIdentifier=error
/instance/org.eclipse.hyades.execution/ECLIPSE_ARCH=x86
/instance/org.eclipse.ui.ide/platformState=1178582587101
/instance/org.eclipse.jdt.ui/CustomFiltersActionGroup.org.eclipse.jdt.ui.PackageExplorer.userDefinedPatterns=.jar
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_HYADES_TEST_CORE=D:\eclipse3.2\plugins\org.eclipse.hyades.test.core_4.2.0.v200606131519\hexteh.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.test.core_4.2.0.v200606131519\hexrecr.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.test.core_4.2.0.v200606131519\test-core.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.test.core_4.2.0.v200606131519\bin;
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.PackageExplorer_patternFilterId_$.class=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.compliance=1.5
/instance/org.eclipse.jdt.ui/CustomFiltersActionGroup.org.eclipse.jdt.ui.PackageExplorer.userDefinedPatternsEnabled=true
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_APACHE_COMMONS_LOGGING=D:\eclipse3.2\plugins\org.apache.commons_logging_1.0.4.v200606131651\lib/commons-logging-1.0.4.jar;D:\eclipse3.2\plugins\org.apache.commons_logging_1.0.4.v200606131651\bin;
@org.eclipse.hyades.execution=4.2.0.v200606131519
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_SWT=D:\eclipse3.2\plugins\org.eclipse.swt_3.2.0.v3232o.jar;D:\eclipse3.2\plugins\org.eclipse.swt.win32.win32.x86_3.2.0.v3232m.jar;
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComplete.visibilityCheck=enabled
@org.eclipse.ui.editors=3.2.0.v20060605-1400
/instance/org.eclipse.hyades.execution/CUSTOMPATH_ORG_ECLIPSE_HYADES_PERFMON_AGENTS=;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\extensions\org.eclipse.hyades.perfmon.agents
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_HYADES_LOGGING_PARSERS=D:\eclipse3.2\plugins\org.eclipse.hyades.logging.parsers_4.2.0.v200606190100\hparse.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.logging.parsers_4.2.0.v200606190100\tpglimport.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.logging.parsers_4.2.0.v200606190100\bin;
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=D:\workspace\poker,D:\workspace\shared_object,D:\workspace\sol,D:\workspace\test,D:\workspace\Texas Hold-em
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_HYADES_LOGGING_ADAPTER=D:\eclipse3.2\plugins\org.eclipse.hyades.logging.adapter_4.2.0.v200606170100\hgla.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.logging.adapter_4.2.0.v200606170100\bin;
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.codegen.targetPlatform=1.5
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_HYADES_PROBEKIT=D:\eclipse3.2\plugins\org.eclipse.hyades.probekit_4.2.0.v200606131519
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_HYADES_EXECUTION=D:\eclipse3.2\plugins\org.eclipse.hyades.execution_4.2.0.v200606131519
/instance/org.eclipse.hyades.execution/PROBEKIT_PLUGIN=D:\eclipse3.2\plugins\org.eclipse.hyades.probekit_4.2.0.v200606131519
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterprofiles.version=10
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_EMF_ECORE=D:\eclipse3.2\plugins\org.eclipse.emf.ecore_2.2.1.v200609210005.jar;
@org.eclipse.jdt.core=3.2.0.v_671
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templates_migrated=true
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_HYADES_LOGGING_ADAPTER=D:\eclipse3.2\plugins\org.eclipse.hyades.logging.adapter_4.2.0.v200606170100
/instance/org.eclipse.hyades.execution/LIB_EXTENSION=.dll
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK=D:\eclipse3.2\plugins\org.eclipse.tptp.platform.collection.framework_4.1.100.v200606131519
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_EQUINOX_COMMON=D:\eclipse3.2\plugins\org.eclipse.equinox.common_3.2.0.v20060603.jar;
/instance/org.eclipse.hyades.execution/ECLIPSEROOT=D:\eclipse3.2
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_OSGI=d:\eclipse3.2\plugins\org.eclipse.osgi_3.2.0.v20060601.jar;
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.user_view_bindings=<?xml version\="1.0" encoding\="UTF-8"?>\r\n\r\n<view id=“org.eclipse.ui.console.ConsoleView”>\r\n<perspective id=“org.eclipse.jdt.ui.JavaPerspective” userAction=“opened”/>\r\n\r\n\r\n
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocations.migrated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.source=1.5
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_EMF_ECORE_XMI=D:\eclipse3.2\plugins\org.eclipse.emf.ecore.xmi_2.2.1.v200609210005.jar;
@org.eclipse.team.ui=3.2.0.I200606051140
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_JUNIT=D:\eclipse3.2\plugins\org.junit_3.8.1\junit.jar;D:\eclipse3.2\plugins\org.junit_3.8.1\bin;
/instance/org.eclipse.hyades.execution/CLASSPATH_COM_IBM_ICU=D:\eclipse3.2\plugins\com.ibm.icu_3.4.4.1.jar;
/instance/org.eclipse.hyades.execution/JONAS_HOME=null
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_HYADES_LOGGING_PARSERS=D:\eclipse3.2\plugins\org.eclipse.hyades.logging.parsers_4.2.0.v200606190100
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder.resourceCopyExclusionFilter=.uad,.ucd,.uld,.upd,.udd,.uod,.usd,.utd,.uud,.odd,.ead,.ecd,.eld,.epd,.edd,.eod,.esd,.etd,.eud,.urd.uml,.ecore,.launch
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_HYADES_LOGGING_CORE=D:\eclipse3.2\plugins\org.eclipse.hyades.logging.core_4.2.0.v200606131519\hlcore.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.logging.core_4.2.0.v200606131519\hlcbe101.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.logging.core_4.2.0.v200606131519\tlcbe101.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.logging.core_4.2.0.v200606131519\hl14.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.logging.core_4.2.0.v200606131519\hllog4j.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.logging.core_4.2.0.v200606131519\hlcommons.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.logging.core_4.2.0.v200606131519\bin;
/instance/org.eclipse.hyades.execution/RASERVER_HOME=D:\eclipse3.2\plugins\org.eclipse.hyades.execution_4.2.0.v200606131519\iac-runtime
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK=D:\eclipse3.2\plugins\org.eclipse.tptp.platform.collection.framework_4.1.100.v200606131519\hcframe.jar;D:\eclipse3.2\plugins\org.eclipse.tptp.platform.collection.framework_4.1.100.v200606131519\bin;
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL=2
/instance/org.eclipse.hyades.execution/PLUGINS_HOME=D:\eclipse3.2\plugins\org.eclipse.hyades.execution_4.2.0.v200606131519\iac-runtime\extensions
/instance/org.eclipse.hyades.execution/CLASSPATH=%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;%PATH_ORG_ECLIPSE_TPTP_PLATFORM_COLLECTION_FRAMEWORK%\hcframe.jar;;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%;%CLASSPATH_ORG_ECLIPSE_HYADES_EXECUTION%
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.PackageExplorer_patternFilterId_.*=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.problem.assertIdentifier=error
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_JFACE=D:\eclipse3.2\plugins\org.eclipse.jface_3.2.0.I20060605-1400.jar;
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_HYADES_TEST_CORE=D:\eclipse3.2\plugins\org.eclipse.hyades.test.core_4.2.0.v200606131519
@org.eclipse.help.ui=3.2.0.v20060602
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.PackageExplorer.PackageDeclarationFilter=true
/instance/org.eclipse.jdt.ui/fontPropagated=true
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_APACHE_JAKARTA_COMMONS_LOGGING=D:\eclipse3.2\plugins\org.apache.commons_logging_1.0.4.v200606131651\lib/commons-logging-1.0.4.jar;D:\eclipse3.2\plugins\org.apache.commons_logging_1.0.4.v200606131651\bin;
/instance/org.eclipse.hyades.execution/JBOSS_HOME=null
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_CORE_RUNTIME=D:\eclipse3.2\plugins\org.eclipse.core.runtime_3.2.0.v20060603.jar;
/instance/org.eclipse.hyades.execution/GLA_HOME=%PATH_ORG_ECLIPSE_HYADES_LOGGING_ADAPTER%
@org.eclipse.ui=3.2.0.I20060605-1400
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE_HYADES_TEST_TOOLS_CORE=D:\eclipse3.2\plugins\org.eclipse.hyades.test.tools.core_4.2.0.v200606131519\tools-core.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.test.tools.core_4.2.0.v200606131519\common.runner.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.test.tools.core_4.2.0.v200606131519\manual.runner.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.test.tools.core_4.2.0.v200606131519\java.runner.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.test.tools.core_4.2.0.v200606131519\http.runner.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.test.tools.core_4.2.0.v200606131519\http.hexrecr.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.test.tools.core_4.2.0.v200606131519\http.hextgen.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.test.tools.core_4.2.0.v200606131519\plugin.runner.jar;D:\eclipse3.2\plugins\org.eclipse.hyades.test.tools.core_4.2.0.v200606131519\bin;
/instance/org.eclipse.hyades.execution/ECLIPSE_OS=win32
/instance/org.eclipse.jdt.ui/layout=1
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_code_templates=<?xml version\="1.0" encoding\="UTF-8"?>
*** Current Install Configuration:
Install configuration:
Last changed on 29/08/2006
Location: file:/D:/eclipse3.2/configuration/org.eclipse.update/platform.xml
Configured sites:
platform:/base/
Configured features:
ID: org.eclipse.platform, Version: 3.2.0.v20060609m-AgOexn6hlEUsvBO
ID: org.eclipse.rcp, Version: 3.2.0.v20060609m-SVDNgVrNoh-MeGG
ID: org.eclipse.platform.source, Version: 3.2.0.v20060609m-AgOexn6hlEUsvBO
ID: org.eclipse.jdt, Version: 3.2.0.v20060609m-F7snq1fxia-Z4XP
ID: org.eclipse.jdt.source, Version: 3.2.0.v20060609m-F7snq1fxia-Z4XP
ID: org.eclipse.pde, Version: 3.2.0.v20060609m------6zXJJzJzJq
ID: org.eclipse.pde.source, Version: 3.2.0.v20060609m------6zXJJzJzJq
ID: org.eclipse.sdk, Version: 3.2.0.v20060609m-GNq6oQq-7es-Y81
ID: org.eclipse.rcp.source, Version: 3.2.0.v20060609m-SVDNgVrNoh-MeGG
Configured plug-ins:
file:/D:/eclipse3.2/plugins/org.eclipse.jdt.apt.core_3.2.0.v20060602-1740.jar
file:/D:/eclipse3.2/plugins/org.eclipse.equinox.common_3.2.0.v20060603.jar
file:/D:/eclipse3.2/plugins/org.eclipse.ltk.core.refactoring_3.2.0.v20060605-1400.jar
file:/D:/eclipse3.2/plugins/org.eclipse.ui.workbench.compatibility_3.2.0.I20060605-1400/
file:/D:/eclipse3.2/plugins/org.eclipse.jdt_3.2.0.v20060605-1400.jar
file:/D:/eclipse3.2/plugins/org.junit4_4.1.0/
file:/D:/eclipse3.2/plugins/org.eclipse.pde.source_3.2.0.v20060609m------6zXJJzJzJq/
file:/D:/eclipse3.2/plugins/org.eclipse.ui.workbench_3.2.0.I20060605-1400.jar
file:/D:/eclipse3.2/plugins/org.junit_3.8.1/
file:/D:/eclipse3.2/plugins/org.eclipse.core.jobs_3.2.0.v20060603.jar
file:/D:/eclipse3.2/plugins/org.eclipse.core.runtime.compatibility.registry_3.2.0.v20060603/
file:/D:/eclipse3.2/plugins/org.eclipse.ui.browser_3.2.0.v20060602.jar
file:/D:/eclipse3.2/plugins/org.eclipse.update.scheduler_3.2.0.v20060605.jar
file:/D:/eclipse3.2/plugins/org.eclipse.core.resources_3.2.0.v20060603.jar
file:/D:/eclipse3.2/plugins/org.eclipse.jdt.doc.isv_3.2.0.v20060605-1400.jar
file:/D:/eclipse3.2/plugins/org.eclipse.equinox.registry_3.2.0.v20060601.jar
file:/D:/eclipse3.2/plugins/org.eclipse.debug.ui_3.2.0.v20060605.jar
file:/D:/eclipse3.2/plugins/org.eclipse.text_3.2.0.v20060605-1400.jar
file:/D:/eclipse3.2/plugins/org.eclipse.update.core.win32_3.2.0.v20060605.jar
file:/D:/eclipse3.2/plugins/org.eclipse.ui.cheatsheets_3.2.0.v20060602.jar
file:/D:/eclipse3.2/plugins/org.eclipse.core.resources.compatibility_3.2.0.v20060603.jar
file:/D:/eclipse3.2/plugins/org.eclipse.swt_3.2.0.v3232o.jar
file:/D:/eclipse3.2/plugins/org.eclipse.team.core_3.2.0.I200606051140.jar
file:/D:/eclipse3.2/plugins/org.eclipse.pde_3.2.0.v20060605.jar
file:/D:/eclipse3.2/plugins/org.eclipse.ant.ui_3.2.0.v20060531.jar
file:/D:/eclipse3.2/plugins/org.eclipse.core.filebuffers_3.2.0.v20060605-1400.jar
file:/D:/eclipse3.2/plugins/org.eclipse.osgi_3.2.0.v20060601.jar
file:/D:/eclipse3.2/plugins/org.eclipse.ui.ide_3.2.0.I20060605-1400.jar
file:/D:/eclipse3.2/plugins/org.eclipse.rcp_3.2.0.v20060605.jar
file:/D:/eclipse3.2/plugins/org.eclipse.ui.navigator.resources_3.2.0.I20060605-1400.jar
file:/D:/eclipse3.2/plugins/org.eclipse.jdt.core_3.2.0.v_671.jar
file:/D:/eclipse3.2/plugins/org.eclipse.ui.externaltools_3.1.100.v20060605.jar
file:/D:/eclipse3.2/plugins/org.eclipse.osgi.util_3.1.100.v20060601.jar
file:/D:/eclipse3.2/plugins/org.eclipse.platform_3.2.0.v20060601/
file:/D:/eclipse3.2/plugins/org.eclipse.update.configurator_3.2.0.v20060605.jar
file:/D:/eclipse3.2/plugins/org.eclipse.team.cvs.ssh2_3.2.0.I200606051140.jar
