Watermark in Standard Edition (VPAPP)
I am using the VPUML Standard edition. When I try to export a diagram as a image or print the diagram out directly, the watermark always overlap with the top portion of the diagram. Is there a way to push the watermark up a little bit so that it does not overlap with the diagram? Or, is this done deliberately?
Kelvin
Hi Kelvin,
This is done deliberately to prevent the product being used for Commercial Purposes.
Martyn
Why is there watermarking in the Standard Edition? According to the product description, http://www.visual-paradigm.com/productinfovpumlse.php, the watermark is removed for this edition?
Confusingly, the same is supposed to be true for the Modeller edition.
What are the facts on this exactly?
Please answer the question:
Hi user,
Thanks for your post. Yes, Modeler Edition or above will not have any watermark on diagram output.
I guess you are still using evaluation key so there are watermarks on the diagram outputs. Could you please capture a screenshot of the License Key Manager (Tools > Key Manager) with the options “Expired Keys” and “All Keys” turned on? Thanks in advance!
