I am evaluating Visual Paradigm for UML. When I export a diagram and import it into Word I’m asked to provide a Windows Live login. If I cancel the login requester three times the image is inserted.
What is the cause of this? It only happens with images exported from VP-UML.
Thank you for your post. Could you tell me how did you export the diagram as image? If you took the path “File > Export > Diagrams as Image”, the outcome should be totally independent from VP. And as far as I know, we haven’t did anything special to the exported diagram which cause Word to ask you provide a Windows Live login…
Thank you for your reply. Does all kinds of file formats (e.g. JPG, PNG, EMF…) produce the same problem? Are you sure image files from other sources do not have this problem?
It looks like JPEG, EMF and PNG with background has the problem. I haven’t had the problem with PNG without background.
Also if I have imported one PNG without background the others don’t seem to have the problem. Not until I close the document, open it again and try to import images again. Then he problem is there again.
I have tried other JPEG files and they work as expected.
Does the problem related to the diagram content? Are you able to repeat with a new diagram with simple content such as one use Class shape? If the problem is project -dependent, would you mind providing us your project file to test? Thanks a lot.
I have tried both sequence diagrams and class diagrams. The problem is the same with both diagrams.
If I delete the Thumbs.db file in the image directory and choose “Insert > Image > From file” in Word then the same problem occurs when Word is just scanning the directory and a new Thumbs.db is being created.
I have tried converting one of the diagrams with the problem from JPEG to JPEG using Microsoft Paint. That is just open it in Paint and the save it again in the same format. Then the problem is gone.
So it could look like it is a problem with the export of images. untitled.vpp
It’s a good news that the problem does not exist in your updated tool (it should be fixed in the latest build already).
If there are inquiries in the future, please feel free to ask.
