After I updated to the latest patch (Build sp1_20091125f) I get an error (image attached to post) when opening a generated Word report in Word 2007. The report generated is the default report with only a single requirements diagram selected. vp_project_publisher_requirements_error.jpg
Hi Captain,
Thanks you for your message. Would you mind to attach your project, or send it to lilian.wong@visual-paradigm.com for investigation? Thanks in advance!
I unfortunately cannot send you the model. I will try to generate a new one. I think the problem may have been the settings from the previous version of VP UML. After tweaking a few Word generation settings, it seems to export OK again. I’ll keep an eye out for the issue.
Hi Captain,
Thanks for replying. We recently fixed problems related to Word report generation, would you mind to update your product to latest patch (build sp1_20091125r or later) and see if your problem can be solved?
More details about updating to latest patch are available at:
