i have a business need to create seperate diagrams and have each diagram persist to a different database, i would like to do this in the same DBVA project but apparent you can only have one database connection specified and when you generate code or database it uses all the defined diagrams. there should be a way to specify which diagram you wish to use and the ability to specify multiple database connections.
i guess for now i will need to create separate projects for each database and export everything separately.
are there plans in the future to make the application support exporting individual diagrams and being able to specify which database connection to use?
