Hello Jick,
I was trying to export a model from Sparx Enterprise Architct as XMI2.1 model. When importing into VisualParadigmUML a popup says, that “Enterprise Architect” is not a know system - no import possible.
Regards
Bernd
Hello Jick,
Regards
Bernd
Hi Bernd,
Please provide the XMI file for reproducing the problem.
Here is another example.
Before that I downloaded Version 7.0 of Sparx Enterprise Architect and actual version of Visual Paradigm for UML 6.0.
EA7.0 > ProjectBrowser > “Model” > RC > ExportModelToXMI ==>
“Export Package to XMI”:
Root Package: Model
Filename: D:\KDG…\outtmp\Model-XMI-export-070727b.xml
Stylesheet: none
General Options:
[x] Export Diagrams
[] Format XMI Output
[] Write Log file
[] Use DTD
[] Generate Diagram Images
Format: none
For Export to other tools:
[] Enable full EA Roundtrip
XMI Type: UML 2.1 (XMI 2.1)
[] Unisys / Rose Format
[x] Exclude EA Tagged Values
(Warning: These options are for exporting EA model elements to other tools only)
Export
VisualParadigm-Import ==> “Unknown Exporter: Enterprise Architect”
By the way: Why MUST the exporter be known? For proper diagram ex/import, ok. But shouldn’t at least the model information be portable, since standardized?
Why not just warn and ignore sections that can not be parsed?
Thomas
Hi Bernd,
I have confirmed with our engineers - The current release do not support importing EA’s 2.x XMI. However, this will be supported in the next version, which will be available by the end of the next week. I will inform you once the next version is out.
By the way, I would like to suggest a better way to convert your work to Visual Paradigm’s project. Here are the steps:
Copy %VP-Suite-Install-Dir%/scripts/VP-UML.bat to %VP-Suite-Install-Dir%/bin
Edit VP-UML.bat by replacing RV by v.RE
Save
Run it. This starts the CASE Project Converter.
Select “Import from” for the source
Enter the project file
Confirm the VP-UML Project File
Press Convert.
Hope this helps.
Hi Bernd,
I would like to inform you that VP Suite 3.1 has been released. The XMI importing function has been enhanced to support your need. I suggest you download and have a try. Here is the download page:
http://www.visual-paradigm.com/download/download.jsp?product=vpsuite
