When I try to import any XMI file in SDE-VS, Together hangs with the legend “Revalidating Models …” and the graphic at 100%. At the begining I thought that it was because I was using xmi 1.1, but it happens for any files, even a simple one generated and exported as xmi from SDE-VS. [One sample is attached].
I’m using SDE-VS 4.0 (20070420), I updated a previous version because I thought the problem could have been solved …
Thank for your post. Sorry but we do not understanding what you mean by “Together hangs with the legend “Revalidating Models …” and the graphic at 100%”. Could you capture a screenshot to show me your problem? Furthermore, I would like to collect the log file from you. Please export the log file from the About dialog of SDE, and post here. Thank you in advance!
Thanks for your reply. Sorry for any inconveniences the problem may cause you. Unfortunately, we are unable to reproduce the problem you have. Would you mind trying with a new VS and SDE project, and let me know if this is repeatable? If yes, may I know if you have installed any other plugins into Visual Studio?
