Morning Peter
Thanks for pointing out where the label manager is.
Allows removal. Good.
Doesn’t allow “sorting”; (either manual or auto). Bad. But it will only become an issue if we create more than about a dozen labels. I’m currently on 11.
Can’t give you the exact colour codes for the unreadable because, as soon as I found the edit method, I changed it. but it was Black on Red. And it may have caused me more of a problem than most because I’m red-green colour blind.
While I’ve got your attention, is anyone contemplating the feature suggestion I made the other day? That would make my life a lot easier and I suspect that would be true for anyone else making extensive use of the the glossary. For example, I’ve so far created 142 glossary entries but 43 of those are simply Xrefs (eg abbreviations, plurals, alternate refs) to the substantive entry. So a little under 1 in 3 entries require a two step process from me and a two step process from the eventual reader.
