How to using visual paradigm generate database without foreign keys?
For example, PowerDesigner generates DDL whether to select the foreign key option. Does Visual Paradigm have the same choice?
Hi Donie,
You can check Generate Individual DDL option in Database Generation dialog. Foreign key will be generated in a separate file.
Sorry that it is not supported.
You can either remove from model or generate to individual DDL and skip the fk file.
