Hallo,
I made a sequence diagram and i found a little bit problem. I wanna change the sequence fragments but i’m missing “operation kind” menu and i don’t know the others way to change it. Are there other way to make it?Thankyou…
Hi Agetha,
It is strange because this menu item should exist in the popup menu of combined fragment. Can you open its specification dialog box to see does it read “Combined Fragment Specification” in its title? Just to ensure you are selecting the correct diagram element.
Cheers,
Antony.
Yes you’re right. I’m just realized that i use the wrong element. I used frame element before:sweat_smile: Thankyou for your help…
You’re welcome and glad you have your problem solved!
