I am using version 5.3 SP1 Build 20060811. I note that, in Report Writer, I see join and fork objects in the activity diagram model, for use in reporting, for parts of the diagram that were created in an older version of the tool, but, new forks and joins that were created after updating to 5.3 are not shown in either the model tree or in the diagram tree of the report writer.
Decision nodes do show up okay in the report writer model tree, however.
Update - This happens not only with forks and joins, but, with all objects which are children of swimlanes. If the objects are removed from being children of a swimlane in the activity diagram, they are present in the model tree of Report Writer. The Swimlane doesn’t show up in the report writer, which may have already been reported in the past.
Say, Jick… there is another problem with the Join in the report writer interface… a small thing… the default table size created with the Fork’s documentation has a greater indent than other objects’ tables… So, whenever you regenerate the report from the model the size of the table gets set smaller than the other objects…
Both issues you reported are fixed and deployed. Please perform an update to advance to the newest release. You can update by running the updater inside the bin folder of $vp-suite-install-dir
You are welcome. By the way, a complete release is now available. Please perform an update to advance to that release. You can run the updater inside the bin folder of VP Suite for the update.
