Advised approach of linking questions and answers also discussions to ERD elements
What is the advised approach for discussions, and Q&A? As you may guess there are lots of questions and related answers (raised from varios environmets like slack etc) regarding modelling, which are raised many times. I wonder if there is a suggested approach in VP like tagging and referencing the topic (all the discussion including its history) to a diagram,table or term in Glossary. If yes could it be possible to search the discussion and get the linked, referenced data elements?
I tried it with brainstorming diagram but I’m not sure if this is the proper way?
Best Regards,Seyhmus
Hi Seyhmus,
Thank you for your post. You can use the PostMania feature to keep track of discussions. By sharing a diagram with someone via PostMania, that person can view the diagram in a web browser, and leave her comments. You can read the comment and reply it accordingly. The following tutorial gives you more ideas about how the feature works:
https://www.visual-paradigm.com/tutorials/communicate-business-process-design.jsp
Hope this helps.
Hello Jick ,
Thanks a lot for your answer. Which license type is enough to use PostMania. Is team server and Modeler enough or does it require an additional fee?
Thanks in advance
regars
seyhmus
Hi Seyhmus,
Thank you for your reply. PostMania is available since the Modeler Edition. It does not require an additional fee unless you want to host the Teamwork Server in your environment.
